Wiring diagram
Hi All, Does anyone know if there is a wiring diagram on here for the front  electric windows for a 2007 Fabia 2? TIA
Here you go........
What's the issue your having ?
Cheers mate. The passenger window doesn't work from the drivers side. I've replaced the switch still not working. The switches work the opposite way as in push down to make the windows go up. One touch operation doesn't work. I have to reset the windows by putting the keg in the drivers door to get them working then they only work for a short while.
Did you fit a Fabia switch / genuine Part ?
I don't know if it it was genuine or not. Got it from Amazon
got a link to it ?
It was an aftermarket switch
