dsg 7 maintenance
I received an answer from an authorized service that there is no service plan for the DSG 7 gearbox, is that really true?
True if a DQ200 7 speed twin dry clutch DSG.  (but not if a 7 speed wet clutch one. )
So is it fitted to a 1.0, 1.4 or 1.5TSI or a 1.6TDI?
Maybe after 8 years or around 100,000 you might want to be changing the 2 oils that a DQ200 DSG have,
but many will not bother.
1.6 Tdi authorized service no service plan says that for dsg 7 gaerbox sealed no oil change
23 minutes ago, e-Roottoot said:
Istina ako DSQ dvostruka suha spojka DQ200 sa 7 brzina. (ali ne ako je u pitanju mokro kvačilo sa 7 brzina.)
Pa je li ugrađen na 1.0, 1.4 ili 1.5TSI ili 1.6TDI?
Možda biste nakon 8 godina ili oko 100 000 mogli zamijeniti 2 ulja koja imaju DQ200 DSG,
ali mnogi se neće gnjaviti.
how do i know which clutch is now made from octavia 3, dsg 7, 1.6 tdi 2019.  they say they do not have a service interval from the manufacturer.
It is a DQ200 DSG if a 1.6TDI.
 It is if FWD and with an engine producing no more than a 250Nm of torque.
That is how it has been since 2009.
(As for a Sealed Box, well there was the World Wide Recall in 2012 & the European Service Campaign from 2014 when the Oil was changed from Synthetic to Mineral in boxes 2009-2012.  Then there are members here that do oil changes as nothing is sealed for life if it has a drain plug and a refill place.)
Edited by e-Roottoot
7 minutes ago, e-Roottoot said:
To je DQ200 DSG ako je 1.6TDI.
 To je ako FWD i s motorom koji ne proizvodi više od 250 Nm okretnog momenta.
Tako je to od 2009. godine.
(Što se tiče zatvorene kutije, dobro je došlo do opoziva širom svijeta 2012. i Europske servisne kampanje iz 2014. kada je ulje promijenjeno iz sintetičkog u mineralno u kutijama 2009.-2012. Ovdje su članovi koji vrše zamjenu ulja jer ništa nije zapečaćeno za život ako ima odvodni čep i mjesto za ponovno punjenje.)
what do you suggest me to change the oil for how many kilometers and which oil to change, that the engine is 1.6 Tdi Dsg 7, the vehicle is 2019 production with 34000 km
If you still have the car in 2027 maybe think about having the oils changed but that is up to you.
There is no service interval or regime or any recommendations for doing any servicing on a DQ200 DSG.
It is a case of doing nothing unless you have a fault.  They can need Clutch Packs, they can need new or refurbished Mechatronic Control Units, they can go wrong, but not according to the VW Group.
So there is no Servicing Schedule or Recommendations from the VW Group.
Some do preventative servicing but that is their and your own choice.
