Talex update
Is anyone having problems uploading a current update to their talex detector?
i usually have no problem but today i keep getting a message that the update has failed and i should check the connection and make sure im on line.
Ive turned off my firewall and still get the same problem.
So was wondering if it is a problem at Talex end before i start smashing up my computer
I had my Talex replaced because of that same problem and even having done so I still encounter uploading snags from time to time (it's not just you!). What I have tried (and has worked for me so far!) is to switch off Talex and turn on again in DP mode but holding power cable firmly in place, may take a few attempts but generally works.
Apart from this glitch, the detection and use of this product is top notch but stops it from being 10/10!. :(
Ive tried your idea a few times to no avail
I will phone talex up on tuesday and have a bitching session
I concur about talex out and about on the road though,its excellent
Its worth having just to have a speedo that gives you a true speed reading:thumbup:
