Identify this pneumatic connection ?
Can anyone identify this pneumatic connector type, it's on a Sealey coolant system pressure test kit, they use the same connectors on their Turbo pressure test kit,  I've contacted Sealey and they say they have no idea of what type of connector is fitted which seems a bit odd ?  A Google picture search only came back with a lighthouse !! and searching for "pneumatic quick release couplings" hasn't found anything yet
It is the Continental equivalent of the PCL airline fitting, I have loads of them in my spares box as my airlines use PCL connectors so I swap them. I also have several of the couplings
All airtools sold in France at the Brico-sheds use them.
9 hours ago, J.R. said:
That looks the closest but physically much bigger according to the PDF
Those are the standard "Euro" connectors, I have these on my compressor and they don't mate with the unkown fitting
I have a pressure brake bleeder which uses a similar dry break coupling, my stuff is stored in several locations and I have no idea where it is to check it.
What are you trying to achieve?
I want to purchase a couple of replacements if possible to make up some custom adapters, for a non automotive project and still use the Sealey hand pump unit
