Headlight not working
Hello, when I replaced the das Handschuhfac, there was a short circuit, and then all the headlights did not work. Can you help me?
1 hour ago, Abdu said:
Can you help me?
No. not least because I don't know what language "das Handschuhfac" is in.
When you replaced the glove box you may have trapped a wire which then became a short to ground or disturbed a damaged wire.. A fuse will have blown so first find the blown fuse and then look in your handbook to see what circuits it protects. Check the functioning of all listed circuits as a check.
The headlights are switched electronically but there are fuses in the engine bay F16 and F26 (see page 226 or thereabouts in your handbook for fuse location) [Note each fuse protects one headlight and the opposite rear light so check rear lights too]
You will probably have to remove the glove box to find the fault before replacing fuses.
I have completely removed the light In glove box and all fuse is good but Headlight not Working
Glove box*
26 minutes ago, Abdu said:
Glove box*
OK. Earlier I could see that you are Finnish, but the word pair looks Germanic or possibly Danish, so I couldn't even start. I'd agree with @pikpilot about the trapped wire behind the glovebox, and suspect that you've blown a fuze in the battery top fuzebox, not the fascia one.
I’m from Syria but I live in Finland I check all the fuze all is good and i check glove box and I don't see anything suspicious could something else happen?
Go and put a diagnostic tool and I guess you’ll see what went wrong with your electricals.
I dont know what language Fuze and Fuzebox are in 😆
For Abdul who I notice is now writing Fuze your spelling was correct the first time with Fuse 👍
Edited by J.R.
