Please Help - Breather pipe fitting on top of engine broken
Hi All,
Whilst undertaking the dreaded EGR cleansing, my magnetic torch dropped from where it was secured on the bonnet and landed on a hose.
The result was a broken fitting that is allowing air to enter the system.
I have tried to Google the part with no luck, just wondered whether anyone here would be able to help with a part number or advice please?
Photos attached, Nick
Engine code off your V5 will help, CAXA12345 for example.
Part number is on the hose 🤔
I hadn't seen that 🤣, thanks
I think that part number is only for the hose itself... so you still need the actual bit you broke (though that might have PN you need)
Managed to find a complete pump with hose attached for £10 on eBay incl postage...that'll do 👍
