Wiring diagram
Hiy does anybody have wiring diagram for rear wipers and wash as it seems it runs from different control module to the front window wipers? Cheers
I can assume you are talking about the car in your bio but please be more specific, and also about what the problem is.
The rear wipers are controlled by the same module as the front, the J519 body control module.
Fused at SC47 with a 15A fuse and has 2 wires going to the BCM to control it.
The front is controlled via LIN.
Front window wipers work but back and window washers don’t on mk3 octavia
Edited by Raydstevenson
Sorry meant to add this is wiring diagram according to this they run off different control modules.I’ve tried changing centre and control sticks on steering colum with no success all fuses are perfect.so now iam at a loss ???
Fractured cables in the rear hatch gaiter, probably one of the twisted pair for the canbus module contained within the rear wiper.
Would not explain the rear washers but that could well be a blockage or displaced pipe joint and have no connection to the rear wiper fault.
Edited by J.R.
