Window Woes. Very peculiar
The rear nearside window has started opening when the car is locked and unattended.  I can open and close the window but it opens when I press the switch to close it and closes when I press the switch to open it.  This is the same for the rear nearside door and for the switch on the driver's door.
Where should I start looking to correct this?
Thanks in anticipation for any help that you can give.
Nick
May be anti-pinch system need  to be reset ?
Try resetting, by opening each window , then closing and holding switch in close position for a few seconds, a click may be heard, do all windows the same way.
Thanks both.  I'll have a go.
The reverse action of the offending window is worrying, though.
Nick
No joy, I fear.  Can anyone recommend an expert near me HR5, Kington?
N
