Skoda karoq 1500cc gasoline transmission noise
Hi all! I'm new here and new owner of a skoda karoq 1500cc manual transmission of 2022.
I searched the forum, but I couldn't find similar so I'm starting a new topic.
The issue is a rattle noise when I have gear on ( no matter what gear ) from the transmission which becomes
louder when switching between gears.  The sound stops when I press the clutch.
I went to my car dealer, they spotted the noise and they told me that skoda knows about it and they consider it as normal
and that many models have it.
So my question is, does anyone else has the same issue or is just me? They just offered to add some screws and PROBABLY
will fix the issue.
I'm posting a video of the noise, camera is not so good so you will hear wind, but you can hear a metallic noise
along the video.
https://www.youtube.com/watch?v=MLFzH3k-OJs
Any help appreciated
Thank you!
Welcome to the forum.
Which country are you in?
Who was it at your car dealer that was just giving you a line, was it a mechanic / technician?
You best go to see another Dealership or Main Dealership if they were not a Skoda garage or even if they were.
First of all thank you for your time!
I live in Greece. I went to an official representative of Skoda ( Main dealer + service ) since the car is still under warranty
and the one who told me that was the manager who supposed to be a mechanic also.
I won't leave the matter, cause it's not normal such a noise to be "normal". It's very annoying and from the other side
it's a security issue.
  • 2 months later...
will fix the issue.
along the video.
Thank you!
Hi,
Please check (when the engine is cold) move /pull slightly the the turbo actuator, i have the same rattle noise only in first gear at ~2000-3000rpm.
If is that then you should ignore it, nothing will be affected :)
