SQUEAKY CLUTCH PEDAL
My recently purchased Octavia has a very creeky squeaky clutch pedal.
The clutch operates perfectly nice and smooth but the pedal is awful.
Is this common issue ???
Big job to take pedal of and grease up relevant parts ??
Cheers all for any advice given 👍👍
A quick spray of silicone or a light spray grease up at the pivot and working with your hand will be more than enough to cure a squeaking pedal. No disassembly required. Although you could take the plastic panel above the pedals off for better access but shouldn't need to.
You will want to put a rag over your foot pad on the pedal to catch any drips or overspray. Pedals can be slippy enough when they're wet, nevermind with something else to help!
Cheers pal 👍 appreciated
