Help with vcds
Flokis
Recommended Posts
Why do you need it?
You should be able to access the controller for all the other functions.
Link to comment
Share on other sites
If changing the coding doesn't clear the fault, then the LED's you have don't match what the BCM expects so will always flag a code. Either get better LED's or use load resistors.
There is no security code required for this...
Please add a full autoscan to your next post and add exactly what instructions you're trying to follow :)
  • Thanks 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
