disable flickering led high beam after start
Hi.
I replaced the high beams with led.
They flash 3 times when you turn the key.
I have tried everything via vcp, turning off cold/warm diagnostics and flipping the lamp type but they still flash.
Anyone advice ?
That's probably because the system checks these lights at startup. With halogen bulbs these short pulses are unnoticed.
Was there a particular reason to replace these bulbs? I use high beam less than 1% of the time, and have no complaints about the enormous amount of light that my bi-xenon headlights (together with the Halogen high beams) emit.
thanks for the reply
I use the high beams a lot and I'm used to them from my last car
So I turned off the cold diagnostics on license plate, daylight and reverse light but on high beam unfortunately, has anyone solved ?
Vag Can Pro
well
next update
I've got it all figured out
Except for the front fog lights, I don't really know how to do that .
Does anyone know how to turn off the cold diagnostics on the led front fog lights?
