Fabia vrS standard Symphony Radio/CD
Hi, I recently bought an 05 vrS and it has the standard spec Symphony unit in it. However, I am appalled at the quality of the FM reception on it. Sometimes its fine and other times its as if it slightly off station, distorted etc.
I have done a search on this forum but is it a case that this unit is accepted as being not good, or is there something up with mine? I must state, I am not into upgrading or anything, I just want to be able to listen to the radio without it being distorted!
I commute through Glasgow on the M8 and listen to local stations if thats relevant.
Thanks in advance for any advice offered.
Its not designed to work properly North of Gretna!!
I have no problems with the unit in those terms - but I have concerns re its over sensitivity to picking up both spurious traffic reports and traffic reports from a long way away. When I'm driving to work through Gloucester I don't want the traffic reports from Radio Shropshire - likewise when I do actually go to Shropshire I get traffic reports from Radio Sheffield! The dealer says there's nothing wrong - I should be glad reception's so good!
Hi' date=' I recently bought an 05 vrS and it has the standard spec Symphony unit in it. However, I am appalled at the quality of the FM reception on it. Sometimes its fine and other times its as if it slightly off station, distorted etc.
Thanks in advance for any advice offered.[/quote']
I switched my standard HU not long after buying the car and had a signal booster/amplifier fitted at the same time (about
Newbie Question - How do you turn the Traffic Announcement (TA) off?
Pushing the TA button does nothing!
It is really annoying!
Apologies for posting this twice..
Whilst NOT receiving a TA. Switch on the radio, hit the AF button.
This selects the non-TP FM presets.
If you ever want TAs, hit the TP button.
NOte: The TP button isn't just a TA switch, it's got its own set of TA dedicated presets.
...which as I've said before, seems a strange way of doing it...
J.
Cool Thanks Vindaloo:thumbup:
