Headlight range fault
Hi all. I wonder if anyone can help.
I've attempted to code high beam assist onto my 03FL using the method on the pinned thread and now I have headlight range warning on the dash.
It requires basic setting carrying out but vcds won't do it. Anyone had this before or able to point me in the right direction?
Thanks!
Maybe post a full autoscan along with the instructions you followed :)
Thanks!
I can confirm that VCDS definitely DOES do it....unless you happen to own no non-genuine version of the software; in which case you might be given short-thrift here on Briskoda.
Thanks for the replies. It is now sorted😁
