VCDS Security acces code for 09 control electronics in Superb mk2
Hello, I have been trying to enable foglights corner lighting function(I'm not sure if that's the propper name as english is not my firs language but I mean the function that when you turn the stering wheel the respective foglight turns on). A guide on yt showed that i need to get security acces and than change settings in the adaptation tab. However i can't find anywhere the security acces code and vcds doesn't show it either. If anyone knows what the code is I'd be greatful if you shared the knowledge. The car is a 2012 mk2 Superb estate with the 125HP TSI engine.  Thanks in advance for any help :)).
Did you swap your cable as per your other post?
If so then try 31347.
Yeah I got myself a hex-v2 cable. Thanks for the code I'll try it :D
What guide are you following?
Pretty sure in a MK2 cornering fogs are part of the lcode and not an adaptation channel...
Can you post an auto scan and adaption map from 09?
Actually now I think about it you are right, it’s been a while since I’ve done a MK2
Sorry for not replying(my laptop broke and i hat to take a break from this) but here is a link to a guide i'm trying to follow(I know it's for a mk3 octavia but i thought it'd be simmilar(sadly it's not in english)https://m.youtube.com/watch?v=VpRtxzfva_w
