Help required: Fitting phone in Fabia
I've fitted loads of car kits over the years and always used the no drill mounts from www.dashmount.co.uk and never had any problems - until now that is.
If just fitted one of their mounts (http://shop.dashmount.co.uk/additions%20feb/70381.htm) into a Fabia Elegance.
With the Elegance level of trim you get a little drawer under the stereo unit, and it this drawer that is the problem - without bending the bracket the drawer won't open - even with the bracket bend it needs packing out so the glove box can open. Even the bit of trim removed won't go back and allow the drawer to open. Dashmount don't seem interested in helping in anyway!
The end result is a real mess. I've tried to convince the customer that the best solution would be to swap the drawer for the more normal tray, but they don't want to do this.
Has anyone else got a better "no drill" method for mounting the handset?
Would it be possible to mount it on the other side of the dash, and bend the bracket so it's angled more towards the driver, at the same time allowing the draw to clear the "claw"...
Rob.
Nop - for that you'd need a LHD bracket... If I could find a supplier for the LHD version I'd try it!
Oh...thought that you could just unbolt the bit at the back of the "claw" and put it the other way round...
Howabout some velcro? :)
Rob.
  • 2 years later...
Yep, I had exactly the same problem today while trying to set up a handsfree kit in my wife's Fabia Elegance !
The bracket I bought either fouled the glove box lid or the drawer in a word totally useless ! :mad:
I eventually decided just to fabricate my own bracket which I mounted between the gear lever and the ashtray on the passenger side of the transmission tunnel. This required some cutting of the plastic underneath the ashtray on the inside of the tunnel (which isn't seen) to allow me to mount the bracket with two self tappers on the inside surface of the tunnel. The result now looks really good and it is positioned in such a way so as to not foul the ashtray lid when it opens. :thumbup:
Also I was going to position the microphone using the adhesive pad supplied onto the courtesy light surround but on closer inspection of the light unit there is already a small grill built in behind which you can actually mount the microphone keeping it hidden from view .. nice ! :thumbup:
Just awaiting some connector blocks I ordered now to allow me to fully integrate the hands free phone into the Skoda Symphony Radio / CD unit and the installation will be complete !:)
With the Elegance level of trim you get a little drawer under the stereo unit' date=' and it this drawer that is the problem - without bending the bracket the drawer won't open - even with the bracket bend it needs packing out so the glove box can open. Even the bit of trim removed won't go back and allow the drawer to open. Dashmount don't seem interested in helping in anyway!
[img']http://www.hightrecktechnicalservices.co.uk/misc/fonebracket.jpg[/img]
Alternative is to get a Parrot CK-3100 handsfree kit and go Bluetooth. The Parrot controller can do everything including browsing the phone book and dialling. A lot smaller too. You can get one for less than £80 nowLook Here
Yeah, that looks neat & would probably do the job although I see that you don't have "the drawer" that causes all the problems in your vehicle and I'd still have to find somewhere else to mount it although granted there would probably be loads more options available given it's size. :thumbup:
Having a Nokia phone with bluetooth I went the bluetooth route in my own car and it's definitely the way to go ! :)
Yeah' date=' that looks neat & would probably do the job although I see that you don't have "the drawer" that causes all the problems in your vehicle and I'd still have to find somewhere else to mount it although granted there would probably be loads more options available given it's size. :thumbup:
Having a Nokia phone with bluetooth I went the bluetooth route in my own car and it's definitely the way to go ! :)[/quote']
I have an Octy Myself. that photo was from a furby thread. You can get the Parrot kit Here
This is how I fitted mine and what it looked like
Could a phone bracket not be attached in the same place i have my ipod mounted below:
Its a brodit backing plate that you can then attach anything too.
I suppose so Richard but I wanted to try and mount it so as not to obstruct anything ie the centre drawer in the Elegance model, glove box, switches, ashtray, vents etc.:ne_nau:
was just a thought :thumbup:
Yep, and a good one too. :thumbup:
I reckon I might have gone for that at the point when I discovered the "no drills" dashmount didn't work :mad: but I decided to persevere and found another location.
The problem with the Fabia is that the visible areas of the dash are all used (as you might expect) for other things.:rolleyes:
Moving the mount down to the centre tunnel seemed the next best way to go the problem being how to do it without making holes which would be visible if the mount was ever removed ?
By mounting the bracket between the ashtray and the tunnel with all holes on the inside and under the ashtray seemed the best solution to me.
It is interesting however to see how others have got round this problem. :thumbup:
Yep' date=' and a good one too. :thumbup:
It is interesting however to see how others have got round this problem. :thumbup:[/quote']
Well good luck with it... keep us posted with what you end up doing, could help others out in future :thumbup:
The newly mounted phone can be seen HERE the bracket is mounted down between the side of the ashtray (and still allows it to open without fouling) and the tunnel and secured on the inside out of sight with a couple of self tappers. The wiring running from the bottom of the mount will be fed down the side of the gear lever gaiter & inside out of sight once I have the connectors I require to finish the job.
Hope this is of use to anyone else trying to mount a phone in a Fabia Elegance with a drawer in the dash. :)
