DSG OIL TEMPS
hi what is the purpose of the temp setting when doing the dsg oil? sorry if it seems a dumb question, new to this........
To set the level right since gearoil expands when hot.
Should set level when oil temp is between 35-45 degrees celsius. When operating temp, 77-87 degrres celsius, the level will be just right then. Do not check and set level when gearoil is below 35 degrees.
