Fabia DQ200 fluids
Changing my Fabia DQ200 fluids next month, any hints or tips ?
Ues oem oils gearbox oil part number is G055 512 A2 takes 1.8L
The mechatronics oil part number is G 004 000 M2 takes 1L
The drain plugs are on the bottom of the gearbox m14 for the gearbox one and m6 for the mechatronics one i think can't remember
Need to remove the battery and air box and dust cap at the back of the gearbox by the selector unit and the one by the starter motor for the mechatronics there is a fill plug for the mechagronics but you will need to remove the starter motor to access it how I change my oil I got a one liter bottle with a screw cap and a long hose and filled it that way it's not a hard job but you'll need to take a couple hours to do it right but oils a bit slow going in the gearbox and the mechatronics unit
Edited by Rsrob
Fantastic thanks
Comprehensive reply 🙂
Consumables ordered along with drain plugs and appropriate tubing
Don't forget the oils and tools for the job 😁
if you need any further information or assistance just send me an DM happy to help 👍
Both mechatronic and gearbox fluids changed today, old fluids slightly dark but no contaminants 🙂
