Door rattle
I have a rattle in my passenger side door when the standard stereo is turned up, it stops when i press against it. Any answers please?
Mine does this too. It seems to rattle from somewhere near the pocket at the bottom. If I push or pull the door pocket it stops. It's such an annoying rattle it drives me up the wall, and increasing the volume to drown it out no longer works, the rattle just gets louder!
I started off by prising the door panel off at the bottom and stuffing a sock in there, this seemed to work for a while then it came back, I tried to reposition the sock but it seemed the anti-vibration tesco size 10 sock had reached the end of it's life-cycle...
I then removed the whole door panel and shook it and hit it but nothing seems loose, so I tried running a bead of silicone where the plastic meets the rest of the doorcard... no joy.
My next fix (bodge) will be to place a couple of blocks of plastic or timber onto the frame of the door to press against the doorcard so it bends it out ever so slightly, thus taking up any 'looseness' and hopefully getting rid of the rattle.
If that doesn't work I'll turn the bass down to zero and get myself a small boot mounted active sub, although this isn't my first choice as I'm not a huge fan of subs.
Halifax Skoda vRS centre fixed that exact problem in my Fab vRS door by padding it out around the speaker..hence no more door rattle...
