Clutch fluid
Just a quick one can any one tell me is the brake and clutch resovoir the same item?
Yes it is. When the dealer changed the brake fluid on my Superb, he couldn't be bothered to bleed the clutch hydraulic system, hence old fluid was left in there to pollute the braking system via the common reservoir. Why are these people so devoid of common sense/dishonest?
rotodiesel.
A mixture of both some dealers of any brand are bad some very bad and very dishonest.
Turns out my leak is from the cooling system just had clutch changed and so rad had to come out hence something not tightened up properly.
But you are right some do not have common sense
