Can Any Help? Attached is a Vagcom Result
Hiaz.. Problem not solved.
Have you tried Ross-Tech's support?
FWIW i would blank out part of your VIN No. & reg No.'s
and they only offer support to registered owners of VAG-COM.
Sorry i assumed the OP had a genuine Ross-Tech lead.
I knew there was a good reason not to buy an eBay special ;)
Thanks Appreciate on that reminder! Keke..
I am in a Country call Singapore!
At a rough guess i'd say the bonnet cable grommet isnt in place correctly. Water tracks down the cable and drips into the connector of the throttle pedal messing about with its signal, certianly a good place to start.
Thanks! Will ask my workshop to check as i dont have a place to Dismantle the vehicle.
Accelerator Position Sensor: Most likely a fault has developed on the electronic throttle unit.
Control Module in Instrument Panel on Comfort CAN: Highly probable that a communication system on the CAN bus has developed a fault. This is non-safety critical as the name suggests, Comfort CAN (which controls niceties like electric seats, heater, radio etc)
Yeap, Apparently the unit have been change by my distributor but still having all these problem again. Moreover the seats button are having 5 faults after swaping them.. Hiaz.
