Non adjusting Xenons
Here is one for all the headlight boffins, my xenons have stopped levelling when I turn them on has any body got a clue?:confused:.
Plus the headlamp washers seem to have failed at the saem time is this a fuse problem.
This sounds like an electrical problem but it will more than likely be the signals to the lamp that aren't working?
Have you checked the fuses? Also you may need to get your headlamp levelling sensors checked?
Have you removed the headlamps recently or made any changes?
VAG-COM may be able to show up some error codes.....
Cheers Mr Baker, no changes have been made and due to my driving schedule I have not got round to checking fuses but will do soon.
Also pics for them wings will be got round to soon as well.
SNOB:)
Plus the headlamp washers seem to have failed at the same time is this a fuse problem.
The only thing that has failed under warranty so far on my Superb are the headlight washers. The pump was exchanged and they now work fine.
