Choke of Favorit
Anoyone who has the detailed setup pages from the service manual of the choke sysytem of Favorit? I could not set it up properly.
You should ask it in the CZ forum! :D
There is a English only section, but not for Favo... :(
Reposting at a Czech forum is maybe not the most helpful advice :rolleyes:
But try the "Other Skoda models" section which is the home of the Favorit experts, hopefully someone there can help you. Or get a Hayne's manual - even when you're free of sensors you still may encounter problems ;)
All I can tell from the haynes is that it controls the warning light on the dash directly.
Is it an auto choke or a manual choke? If it's auto, see if it can be converted to manual, then all you have to adjust is the cable length.
I think it is a manual choke - from the first one they made they had an automatic choke. The last manual choke was on the estelles / rapid.
All the choke is - is setting the throttle at idle. This is controlled by the ECU on many of them.
No Sensor - No Problem.
It sounds like it's a carb model therefore a (horrid :lol:) auto choke. I have no idea about this without a manual.
