can anyone cofirm my front disc sizes
its an octy mk1 tdi elegance 110, can provide chassis number if needed, wanna confirm they are 280mm as suspected, also can you tell me if the carriers are built in to the hub, or not, need new discs pads etc so considering the 312 uprgrade if the carriers are integral, cheers guys
PM me your chassis number mate. :)
280mm disks mate, and carriers integrated with the hubs unfortunately :(
Hope that helps. :)
280mm FSIII mate as I did them myself.
Before you go to the expense of the 312mm upgrade which in your case would be new carriers, callipers, pads, discs and if what Tom says is correct maybe even hubs it might be worth looking at throwing some performance pads and good discs on the standard 280mm set up.
I actually found the FS III seemed to work better than the 288mm set up on the octy II's.
:iagree:
There should be a massive range of performance stuff considering the range of cars that use these brakes ;)
yeah good old gsf will be called soon
