uniteunion
Everything posted by uniteunion
  1. Cool, so Vcds isnt just useful to configure the remote key buttons Haha (face palm, such a rookie myself). I’ll replace it then. Thanks so much again and again!
  2. Hi again! I just took the car to the shop (electrical repair specialist) and hope they get at least, the headlight connections done. I was thinking about what you @langers2k said on replacing the xenon control unit. I’ve been digging the web and figured out that I need to replace the unit my car has installed (guess this one, the Afs version https://www.cars-equipment.com/en/shop/xenon-autoleveling-kits-parts-4/oem-5m0907357f-afs-lwr-controler-for/ ) with this other one https://www.ebay.es/itm/Skoda-Oktavia-Kombi-1Z-LWR-Steuergeraet-1T0-907-357-/333554014020 ( Lwr, non Afs). Does it make any sense to you? I’ve visited the oficial dealer and they wont let me know any of the part number unless I take the car there to be repaired. And guess what, they wont take my car to do that repair (as they are the common just-part-replacers kind of dealer). So, this is as far as I’ve gone. Thanks again for your help!
  3. Wow, that's a lot of bad news😰 Anyway, thanks again for sharing your wishdom! I read this Briskoda post from a guy in Norway that had done this same front swap and didn´t mention all this stuff about lighting. He just talked about new bodywork assembly, if I had known all this mess was going to show up, I might have stop tweaking. But well, the thing is almost done so I will try it till the end! Here it is the scan I did this morning, but I guess it's not showing new things that the diagrams didn't show. Thanks again and again for your help! ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 D HW: 1K0 937 087 D Component: BCM PQ35 H 103 0537 Revision: 00103 AD Coding: 48180ABAF00508C040080080110011E4037000AE626D8160800440040000 Shop #: WSC 73430 790 00000 VCID: 326BFC436DDABA8E527-8067 Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 19060 22 0601 Coding: 00D7B7 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 240609 05 54 0402 Coding: 0730ED 16 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 21 Reset counter: 134 Mileage: 171118 km Time Indication: 0 Date: 2044.14.06 Time: 22:31:20 Freeze Frame: Term 15 On Voltage: 14.25 V ON ON Term 50 Off OFF ON 01493 - Bulb for Blinkers; Front Left (M5) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 3 Reset counter: 121 Mileage: 171161 km Time Indication: 0 Date: 2044.14.09 Time: 18:31:01 Freeze Frame: Term 15 On Voltage: 14.50 V ON ON Term 50 Off OFF OFF 01495 - Bulb for High-Beams; Left (M30) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 24 Reset counter: 100 Mileage: 171158 km Time Indication: 0 Date: 2044.14.08 Time: 09:53:17 Freeze Frame: Term 15 On Voltage: 14.40 V ON ON Term 50 Off OFF OFF 00927 - Terminal 30 (Right) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 121 Mileage: 171173 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.10 V OFF ON Term 50 Off OFF OFF 01516 - Terminal 30; Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 4 Reset counter: 121 Mileage: 171173 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.20 V OFF ON Term 50 Off OFF OFF 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 121 Mileage: 171173 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 11.95 V OFF ON Term 50 Off OFF OFF 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 3 Reset counter: 137 Mileage: 171409 km Time Indication: 0 Date: 2046.14.01 Time: 19:37:44 Freeze Frame: Term 15 On Voltage: 11.60 V ON ON Term 50 Off OFF OFF 00834 - Signal for Activation of Heated Rear Window 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 5 Fault Frequency: 5 Reset counter: 137 Mileage: 171409 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 11.25 V OFF ON Term 50 Off OFF OFF 00059 - Terminal 30 for Interior Lighting 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 138 Mileage: 171418 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.15 V OFF ON Term 50 Off OFF OFF 01493 - Bulb for Blinkers; Front Left (M5) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 100 Mileage: 171447 km Time Indication: 0 Date: 2047.14.04 Time: 10:44:08 Freeze Frame: Term 15 On Voltage: 11.80 V ON ON Term 50 Off OFF OFF 01497 - Bulb for Blinkers; Front Right (M7) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 100 Mileage: 171447 km Time Indication: 0 Date: 2047.14.04 Time: 10:44:08 Freeze Frame: Term 15 On Voltage: 11.80 V ON ON Term 50 Off OFF OFF 01499 - Bulb for High-Beams; Right (M32) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 21 Reset counter: 100 Mileage: 171444 km Time Indication: 0 Date: 2046.14.25 Time: 11:20:16 Freeze Frame: Term 15 On Voltage: 13.75 V ON ON Term 50 Off OFF OFF 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 4 Fault Frequency: 20 Reset counter: 100 Mileage: 171444 km Time Indication: 0 Date: 2046.14.25 Time: 11:20:18 Freeze Frame: Term 15 On Voltage: 13.85 V ON ON Term 50 Off OFF OFF 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 4 Fault Frequency: 20 Reset counter: 100 Mileage: 171444 km Time Indication: 0 Date: 2046.14.25 Time: 11:20:18 Freeze Frame: Term 15 On Voltage: 13.85 V ON ON Term 50 Off OFF OFF 02895 - Supply Voltage for LED Module for DRL and Parking Light; Left 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 19 Reset counter: 100 Mileage: 171444 km Time Indication: 0 Date: 2046.14.25 Time: 11:20:22 Freeze Frame: Term 15 On Voltage: 13.60 V ON ON Term 50 Off OFF OFF 02897 - Supply Voltage for LED Module for DRL and Parking Light; Right 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 19 Reset counter: 100 Mileage: 171444 km Time Indication: 0 Date: 2046.14.25 Time: 11:20:22 Freeze Frame: Term 15 On Voltage: 13.60 V ON ON Term 50 Off OFF OFF ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 1Z0 920 843 E HW: 1Z0 920 843 E Component: KOMBI H21 0110 Serial number: 00000000000000 Coding: 110F00 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod VCID: 3A7BD463BDAA42CE9A7-806F 1 Fault Found: 13639168 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 136 Mileage: 171409 km Date: 2110.14.13 Time: 12:50:02 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb Part No SW: 1K0 907 530 AA HW: 1K0 907 951 Component: J533 Gateway H16 0222 Revision: H16 Serial number: 4020K096230249 Coding: E9817F06000202002302 Shop #: WSC 73430 790 00000 VCID: 66C350135192162E0EF-8033 4 Faults Found: 01305 - Databus for Infotainment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 254 Reset counter: 100 Mileage: 143127 km Time Indication: 0 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 96 Mileage: 143127 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 137 Mileage: 171409 km Time Indication: 0 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 136 Mileage: 171409 km Time Indication: 0 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0142 Revision: 00H04000 Serial number: Coding: 1507354 Shop #: WSC 73430 790 00000 VCID: 3467FA5B57CEB4BE40B-8061 Subsystem 1 - Part No: ID-L fehlt Component: AFS-Lst.-Modul l .... Coding: 00000255 Subsystem 2 - Part No: ID-R fehlt Component: AFS-Lst.-Modul r .... Coding: 00000255 6 Faults Found: 01042 - Control Module; Not Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 99 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 02656 - Power Output Stage for Left Headlight (J667); Not Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 99 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 02657 - Power Output Stage for Right Headlight (J668); Not Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 99 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 99 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 6 Fault Frequency: 31 Reset counter: 100 Mileage: 171158 km Time Indication: 0 Date: 2044.14.08 Time: 09:53:10 Freeze Frame: Voltage: 13.49 V Speed: 0.0 km/h ABS 1 02234 - Right Headlight Power Output Stage (J668) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 6 Fault Frequency: 27 Reset counter: 100 Mileage: 171418 km Time Indication: 0 Date: 2046.14.17 Time: 11:48:17 Freeze Frame: Voltage: 11.50 V Speed: 0.0 km/h ABS 1 -------------------------------------------------------------------------------
  4. And this is the diagram that Erwin gave me for a 2006 standard VRS: P.s: I hope I downloaded the right diagrams headlight.pdf cornering and range.pdf
  5. By the way, this is the electrical diagram of my car. Downloaded from Erwin with my VIN number: right headlight VIN.pdf cornering and range VIN.pdf
  6. Yeh pals, I know that fl xenons are awesome... but I dont like their shape at all, I cant help it! Imho, pre-fl has a sharper nose in general, facelift design looks fatter and with those headlights that remind me a granny’s glasses! Now seriously, I was looking for a Common rail Tdi after having a Golf V “Bkd” whose engine exploded after a oil pump failure 😅
  7. Wow!! That’s a handful of info haha.. feeling a bit overwhelmed, may be I should have done a xenon-halogen conversion (kidding) I supposed that the leveling system and sensors will be a big issue. But, is there the chance to disable the system and just adjust the beam in a fixed position so I wont blind opposite cars (and by the way, pass the technical inspection)?? About the DRL, is It what you mean that I will need to disable them via VCDS? Odis-e sounds unknown to me, is that a similar software? Thanks again Langers2k, you are being so helpful!
  8. Definitely! That sounds a smart thing to do, didnt think about it. Although, Im taking the car to a pro workshop as I need the headlight harness converted from 14pin (original facelift headlights) to 10 pin (newly installed 2006 headlights). Should I do the scan before or after the transformation? Thanks a lot
  9. Hi there! I’m in the middle of a front end modification of my Octavia Vrs mk2. It’s the facelifted version and I’ve modified the front end to the pre-facelift version. All seemed ok till I reached the headlight connecting and coding. Both headlights are Xenon but the car lighting configuration (coding) is made for the facelift version: led Drl, auto-switch on lights and foglight used as cornering. Reached to this point, I would love to get any help so I can disable the Drls, the auto switch-on and the cornering via VCDS. That way, I would get the corresponding headlight configuration For a pre-facelift Vrs. Thanks so much in advance for any tip!
  10. Yep, makes sense to be just removing the harness in your case. That was funny, sorry if I Twisted your brain up. The thing is that in my case, that wasnt possible as the loom is one piece in facelifted models, from the Mirror itself to the door module. Pre-facelift models (your car) have the loom in two pieces (my old golf IV was the same), a long harness from the module to the A pilar area, and there a second connector so mirror cables are shorter and for not to disassemble the whole loom across the door. And yes, turned out that the pins are identical, but it freaked me out that one mirror had 6 cables and the other 7. My Insecure skills in electricity made the swap turn a bit fuzzy haha! p.s: my mirrors move independently, I think! Will check it anyway
  11. Well, this made a funny turn haha! as far as the facelift connector, the part nº is 1K0972928A. What I did is soldering the cables (In your case, facelift mirror to “old” connector). The result is that now I have two mirrors (facelift) without connectors and will order a couple so I can sell them properly. Anyway, I had some gap to draw a quick diagram/pin numbering so you could use it. I hope it does make any sense to you. If it doesnt, it definitely helps removing the glass and seeing where al the cables start from inside the mirror. Good luck!
  12. Yes, they both have the same wiring. And buying 2 new connectors is a good call, that way you’ll he able to sell the facelifted big mirrors. Anyway, you’ll also see that pre-facelift cable is way shorter, so you might add some wire as an extension (the mirrors are connected to the door control module in the center of the door panel, so you might need extra 50cm aprox to reach it) I’ll post the diagram as soon as I can, sorry! My one year old kid doesnt let me surfing on forums as long as I wanted😂
  13. Hi Mrhappy, I just finished the installation this evening. I’m drawing the wire diagram/pin functions. But long story short, pre-facelift mirrors have 7 cables although 2 of them (grounds for heating and blinker ) go into the same pin. So actually, 6 pins are used in the connector. And in facelift mirrors, 6 cables are used (and 6 pins) but the ground is cable is divided into 2 inside the mirror housing (one end to blinker ground and the other to heating ground). Let me a couple days and I’ll draw the sketch into a clean diagram and I’ll post it here. My english might be confusing in the explanation above! p.s: glass colors are the same in my case
  14. Hello there! after searching in the forum and other online sites, I cant find the answer to a problem I found when trying to swap wing mirrors on my Mk2 octavia. It’s a RS facelift with those huge and ugly mirrors, so bought a pair from a pre-facelift octy and found that the connectors and wiring are different. FL mirrors have 16pin conector and 6 cables, meanwhile pre-FL have 12pin and 7 cables. The color of the cableS dont match, and the new model are pluged into a control unit on the door (I suspect this is the main issue) I would be very thankful if anybody had the wiring diagram for both models or even better, if anybody has already done this swap and knows how to do it. Thanks in advance!
  15. Hi to all! This is Jose from Spain. I’m starting the front end swap to my Mk2 Facelift Octy. I’ve been surfing in the forum looking for info, and although there’s a couple posts about the topic, I’d love to get some help from any of you on a pair of problems. I’ve seen that basically I need to swap headlights, wings, bumper and front grille. But my doubst start with the light set up. My Vrs has Day Running Lights, and reversing to pre facelift means losing them. Thats ok with me, but do you guys know if I have to do any modification with VCDS to disable the daylights? Besides, I’m wondering if the new headlights have the same wiring/plug as the pre-FL ones. Is it going to be a straight plug and play swap or the wiring needs a new config? thanks so much in advance for any help and sorry for my english!
