EspenSolgaard
Everything posted by EspenSolgaard
  1. There are no cool stuff at old Superskoda either… http://www.kopacek.com/Skoda/Enyaq/ Does anyone know any site for things like this?
  2. Not in the Norwegian model. Then you have to order an option called Skoda Sound System. However, here is an better option for the sound: https://www.youtube.com/watch?v=AfcF4cCbMUc&ab_channel=bassbrothers.no It is in Norwegian, but I think you get the idea :)
  3. I must first say that I am very happy with the car. It is going well and I think it is a good driver environment. Plenty of space and comfort. There are still a couple of things that I think should be fixed as it is a brand new car and such "little things" after all should not occur. The first is a squeaking noise in the driver's door. It squeaks at the top of the door towards the B-pillar. There's a plastic cover that creaks every time I open the door. The sound also comes when I close the door. I can also move the door back and forth and the sound will come. I have compared with several other Kodiaqs and this sound is missing from all of them. This is not the case with the other doors of the car either. If I thought that new cars with such squeaking noise were perfectly ok, then I would have bought a cheaper Japanese car. CarPlay has 5-8% of the times refused to start up. I have taken some pictures to illustrate this. Sometimes of these, it starts after a long time (2-3 minutes), sometimes it starts if I change the USB input, and other times it does not start until I stop, turn off the car, go out and lock, get lost a few minutes and then start again. I have a video of this without it starting, and it has been over 3 min. Sometimes when I listen to the radio, CarPlay suddenly starts by it selves. I got it om film. Bluetooth connection is also sometimes absent. Sometimes I had to talk to people on the speaker on the phone because Bluetooth on the car would not connect. For the blurtooth to connect, I have to stop, turn off the car, go out and lock, get away for a few minutes and then start again. There is no point in just turning off the car and restarting it. Something of the same with navigation. It has also not started. But very seldom. It has also been sometimes that the sound can not be turned up or down, on the radio. I have managed to get this on film. Here you can see that I turn the knob, but no sound comes. There is no sound when I adjust the steering wheel either. What kind of problems with Kodiaq have you experienced? Sometimes the screen locks/freezes so that it is not possible to change the channel. Fortunately, I have also managed to get this on film. When I first talk about Amundsen, I can tell you that in relation to the Superbene I have had with factory-fitted DAB, and the Fabian we have with retrofitted DAB, the DAB signals in Kodiaq are very poor. In Kodiaqen, it is often the case that the sound is absent in places where the Superbene had a clear and nice sound. Luckiely my dealer have fixed this problem by cange the DAB antenna box within the rear boot door/tailgate. I have also experienced that it says on the screen that I do not have DBA coverage with the icon for no coverage luminous. Still, there is a radio in the car. This is the channel it says it should be. When I lower the volume, it gets lower. When I increase the volume it does not work. I have also experienced that I have turned off the car, the radio screen gets dark, the virtual dashboard goes into final position and shows the car with driving data, while the radio sound is still audible…? I managed to get this on film. It went away after a few minutes. Sometimes I put the car in reverse and the rear view camera does not turn on. I have a picture that there is an R in the display on the speedometer, but the radio is still on the radio. I have also received a picture that the infotainment only shows an outline of the car as if I do not have a rear view camera installed. After leaving the car for about 45 minutes, and then starting it again, there may be a hissing sound from the dashboard. The sound is described as if you are standing in the basement of your house and someone is draining water on the floor above. Then it hisses in the pipes to the crane. Not herring in the drain pipe, but the hissing in the supply pipe. I have also managed to get this on film over time. There has also been a problem with Skoda Connect. I'm sitting inside the house and have to turn on the heat. Then it happened that I did not get in touch with the car. It says offline mode. I have pictures of this. Then it says that I must contact my service partner. The next day it may work again. Other times I can be notified of "No connection to the vehicle" This I also have a picture of. Sometimes it has happened that I have to open the tailgate with the button on the hatch, and when I squeeze the hatch there is a click and the hatch opens about 2 mm. Then I have to press again and it opens electrically. I can then also pull up the door manually when it does not go up electrically. I do not have this on film. I usually do not have time to reflect on all this when I am at work. It takes a lot of time to get all these pictures and movies taken. I have deleted hundreds of movies where things do not happen. It is so that the few times I forget to film my actions, it happens of course… The clock has set several times 1 hour back. Although all settings are correct. And this has nothing to do with winter/summer time settings. The car has now been serviced and has undergone an extra software update and replaced the tuch screen on Amundsen. There is a "brain" behind the screen which is then replaced. The errors are still there. The "problem" with water on the roof is the following: When it has rained a lot, or it rains a lot, water settles on the roof. When I then open the back doors, water flows down the back seat of my Kodiaq. This has to be ab designer fault. I hope they fix this on other models. CarPlay bryter av radioen.mp4
  4. I agree, this is the color I would choose.
  5. Hi, there. I am from Norway. This would be my car if I order a company car in about 1 year. This will be the car: ENYAQ iV 80X 77 kWh 265 HP Kr: 484,680 As I explain a lot of the optionals are included in 80x, thats why the price are set as 0,- kr. Have in mind that £1 is about 11,- kr The equipment are as follows: Climate package plus - Heated front and rear seats, heated spray nozzles on the windscreen, heated front and rear seats, 3-zone climate and heated windscreen. This is included in the car from before. 0, - kr Heat pump. All the Norwegian Enyaqs has it as standard 0,- kr 9 airbags are all included 0,- kr Comfort package plus- KESSY full, Phonebox with wireless charging, Keyless entry and start/stop system advanced. Sun Set with extra sound attenuation, fatigue warning and sensor-controlled electric luggage hatch. Everything also comes with the car from before, except sensor-controlled tailgate. I have had such a sensor - controlled tailgate on Superb and Kodiaq. Sometimes it works, and sometimes it doesn't. I do not need such a hatch, when it is so unstable that I steer the sensor control away. 0, - kr Parking package plus Intro - Parking sensors at the front, rear view camera with area view. Such an area view is not necessary for me, and the other is included in the car. 0, - kr Driver package sport plus - 3-spoke sports steering wheel with heating, recu-paddles, DMS, HOD, progressive sports steering and adaptive chassis DCC. I had DCC on my Superb and I liked it. Great with comfort in the city and on the highway. Lovely with sports on winding country roads. Fine with normal on ordinary driving. This was so good that I want it again. 12,500 kr Comfort seat package plus - Electric front seats with memory, electric adjustment of lumbar support and massage on the driver's side. This is a company car and the passenger can easily adjust the seat manually. I use the car 90%, and we do not drive very much privately. Now it sounds very good with massage and for me who runs 60,000 km a year so maybe it would have been a good idea? I have to put it on hold until I get to test how this works. Currently it will be NOK 0,- Light package plus - Full LED Matrix headlight with headlight washers, LED daytime running lights, extended LED taillights and Crystal Face. The luminous grill was so stylish that I have to have it. 6,900 kr Infotainment package plus - Navigation with online infotainment for 3 years, predictive cruise control and AR Head up display. The test car I tested had HUD. I think that was fine. Good overview and nice info right on the windscreen. Everything I needed of info was right in sight. Right in sight was also the reflection of the piano-painted list / screen / little wall that was to hide the "hole" in the dashboard, which is located on the dashboard. The sun shone on this and reflected a lot. First straight from this list and into my eyes, and from the list and up into the window so that there was even more glare. I'm not going to have this. The other with info and the like. I do not need as I have Apple CarPlay. I do not want predictive cruise control either. This also had my test car. It sounds nice, but the problem is that the car has old info about speed limits. So on the highway I was cruising at 110 km / h and suddenly the car slows down to 90! Pretty powerful ... 90 was an old speed limit. Sometimes it also spotted a speed limit sign on the bridge and redused the speed. This happened several times. It took a while before I realized what this was and got it turned off. Very unpleasant experience. 0, - kr Assistant package plus - Adaptive cruise control (ACC), Side assist, proactive passenger protection, Travel Assist 2.0, lane assist with traffic jam assist and emergency assist and Emergency assist This is included with the car. 0, - kr Family package plus - Electric child lock, mechanical sun blinds at the rear, 230V socket (50Hz, 150watt), 2 USB-C in the rear seat, folding table on the front seat backs and headrest in the rear seat with side support function and blanket. A good package with the outlets and sunblind, but folding table and headrest with side support function is not something I should have, or have used for my use. It will be a regular Family Package for NOK 3.900,- Luggage compartment package - Variable floor, buttons for folding down the rear seat, load elements and luggage compartment net. This is also uninteresting to me. I already have some nets so it's fine. 0.- kr. Metallic paint / Pearl effect It will be Artic silver. 6,600 kr Lodge interior with ambient lighting in dashboard. This is gray and a little reddish. In wool and fabric. I do not like leather seats. Cold in winter, and warm in summer. I think I can glide a little back and forth in the smooth leather seats. Alcantara I think is perfectly ok. There I sit steady. But there is something about the color combo in this Lodge interior that I find exciting. 6,600 kr I will not order the ŠKODA Sound System with 10 speakers and subwoofer. I had Canton in my Superb and was super happy with it. I have Canton in my Kodiaq now and am not happy. In Ålesund there is something called Bass Brothers. https://www.facebook.com/bassbrothersas I will have such a facility. It costs a little more than SSS NOK 10,000 and NOK 3,000 to get someone to install it it. This can be removed again and mounted on another car later. 13,000,- kr Towbar, foldable. I must have that. Also at work. 9,800 kr Mud flaps. So that it does not get so dirty and worn in the paint. 2000, - kr Then the total price will be NOK: 545,000 for the car.
