Everything posted by Moribund
- Skoda Octavia 66 Plate: Rear washer not working
Took my car in for a MOT and service this week. I asked them to look at the rear washer which hadn’t been working for a while. They said.. No sign of a leak. technician has checked and motor is working but new wiper motor is required. Not sure what this means- which motor works and which is broken? The rear wiper is working and the front washers are fine. They’ve quoted me a price of £277 parts and labour which sounds like a lot of money for something I hardly ever use. Is this something I can do myself- they were quoting around £130 for the new motor.
Leak in Boot - Skoda Octavia 66 (not estate)
Just a quick update on this. I noticed that part of the boot lid seal wasn’t pushed all the way down and I was able to pull it off. Someone on here had a similar problem and pulled up the seal, cleaned the area and used Tiger Seal to reapply the seal. Not seen any leaks for 3 weeks despite heavy rain. Thanks to all on here for the advice
Cheers mate, yes that’s the one I have got the metal clip that fell off and if it can be refitted onto the plastic that retains it I’ll do it. I suspect I could find some other way of fixing it back on. Its whether it’s worth removing even more trim to remove the shelf support so I can put the clip back in place. Once the carpets back in and the shelf refitted it’s probably not going to make that much difference
- Leak in Boot - Skoda Octavia 66 (not estate)
It’s the parcel shelf supports ( not sure if this is the exact one but looks similar) . This is covering the seat belt roll . I’ve only removed the part in the left hand side to remove the carpet. The fitting is on the left looking at the image and there is a square plastic area which goes through a square cut out in the carpet and then a steel spring clip which snaps into a metal hole in the boot. The clip part has fallen away and l was wondering if it’s worth removing the whole piece Looking at this image I’m wondering if you need to remove the white trim that comes over the top of it.- Leak in Boot - Skoda Octavia 66 (not estate)
Managed to remove the trim and inspect the washer pipe. As I expected the pipe union was intact with no sign of any leak. I’m starting to think that the boot seal may be at fault and I’m testing this over the weekend. I now have a problem refitting the plastic trim that houses the sear belt roll. On the fitting nearest the back of the car there is a plastic locating lug and a spring metal clip with a plastic surround which snaps inside the metal hole. The springy metal bit has come away from the plastic. Not sure if it snapped off or can it be refitted but it seemed to just fall off - if it can be refitted I may have to remove the whole plastic piece (which it looks like you’ve done in the photo). How does the piece come off at the end where the seat belt goes through? cheers- Leak in Boot - Skoda Octavia 66 (not estate)
Many thanks for your help mate - appreciate it. The wettest area is in the small storage area on the left behind the light cluster. I will try hosing this from the outside and see if I can see any water coming in.- Leak in Boot - Skoda Octavia 66 (not estate)
Yes there’s rubber tubing at the top of the boot lid at left and right. I'm trying to work out from your photo what position inside the car I’m looking at? Ive stripped away the inner walls on the left of the boot and the area but not as far as the rear seat belt. Immediately behind the left light cluster is sopping wet. Nowhere near as bad on the other side. If it was coming in through the light cluster it must have been happening for a long time given the volume of water Tried to identify the water pump but the washers don’t work with the bonnet up. Is there a way of running in maintenance mode?- Leak in Boot - Skoda Octavia 66 (not estate)
Discovered the carpet in the boot was damp today and after lifting the carpet out I saw 4 inches of water in the cavity where the spare wheel fits. I cant see any sign of obvious wear in the boot seal. A local garage suggested that the light cluster seal can often cause leaks - I wasn't aware that my back lights had rubber seals. This has clearly been going on for a while and I'm surprised I dint hear the water sloshing about. Local garage suggested removing inner trim and lying in the boot whilst my wife hosed the back of the car to pin point the leak. He did say that the whole light cluster may need replacing if it was taken out Has anyone else experienced leaks in the boot ? Were the light clusters the problem or the boot seal itself? Any suggestions would be very welcome - Leak in Boot - Skoda Octavia 66 (not estate)
