MrUkSkodaDriver
Finding my way
Everything posted by MrUkSkodaDriver
  1. Thanks Sussamb, I checked my sunglasses but it wasn’t the issue. It seem to be getting less so I think it may be some debris in the climate control system which is slowly clearing
  2. Kamiq KAMIQ SE TSI S-A 2024 I have recently noticed an annoying rattle coming from what I think is the climate control area (but could be anywhere in the front of the car). This rattle comes in when doing at least 40 mph? It is a sort of clicking sound. It doesn't appear to be coming from one of the dashboard panels. Has anyone else had this issue ? Any help appreciated
  3. Thanks Pete - this is useful to know.
  4. Hi All, Superb 2.8 petrol Mk 3 2018 L&K I am trying to find the fuse for the rear washer pump as the pump no longer works (no noise when rear washer system engaged). The front windscreen washer pump is working ok. I'm hoping that the problem is only a blown fuse but can't find it's location/number in the online manuals I've looked at. Any help appreciated
  5. The issue still occur now and again but I put some sticky pads on the inside of the glove compartment draw/lid to help vibration rattle which helps. I may have had multiple rattles. It can be difficult to determine the source of a sound so it could be coming from the glove compartment - worth padding the lid area to see if this helps. My car has had new front shocks, new tyres and wheel alignments work over the last 2 years which may be having an impact as well. TBH, I never did find the source of the rattle(s) but it occurs so infrequently now that I have almost forgotten about it.
  6. Yup exactly. AC is ok at the moment so I'm going to leave it as it is. The receipt thingy is a good idea which I will try to remember to ask for
  7. Probably better to get it serviced when it is empty - then you know it has really been topped up!😀
  8. They quoted me £140 for the AC service 😟
  9. Many thanks marineboy
  10. Over the last 2 years I have been using a combination of main dealer and independent garage servicing/work (indy). I recently took my Superb into the main dealer for some work and they reported that the AC service was due. The indy did a pollen filter change last year. Does anyone know what is the difference between an AC service and pollen filter change ? Does the AC service go beyond the pollen filter change etc ? Any help appreciated.
  11. Thanks all for your postings, replaced the resistor and it seems to be ok now
  12. Thanks Breezy_Pete - this is really useful
  13. Crasher - it's a problem on all speeds. Probably a blown fuse but maybe resister pack issues as well. Any idea if there is more than 1 fuse for the blower system ?
  14. Thanks KeithCheetham - It was working on full speed and then just stopped working on all speeds. Does not work at all now. It's AC but not climatic system
  15. Hi, Fabia Mk 2 2014 1.2 S The blower fan has stopped working for the 2nd time in the last year. A local garage replaced a fuse and got it working last time. If I remember correctly they said that there is a second fuse which had blown (I checked the main fuse box and all fuses were ok last time). I wasn't aware of any other fuse. Any idea where this 2nd fuse may be ? Any help appreciated
  16. Thanks varooom ... "I should have gone to Spec ......." 😀
  17. Hi All, Does anyone know what the torque settings are for a Superb Mk3 19" Alloys ? I can't find this in the owners manual in the Skoda connect app or online ? Any help appreciated. Thanks
  18. Just posting an update - the problems was a No 1 coil pack failure. Replaced that and it has sorted out the problem No 1 coil pack failure. No 1 coil pack failure fixed this
  19. Thanks toot. It is a 1.2 TSI and yes, it looks like the same issue as the posting a year ago. I will change the spark plug tomorrow and update. Cheers
  20. Fabia 2014 I was driving along a motorway last night when these warning (ESC warning light (red) and EPC light) lights came on. There was a loss of power and what seemed like a mis-fire within the engine. Would the ESC failure cause this loss of power ? I looked at the engine bay and the Fabia engine seems to be jumping a bit - seems like a mis-fire to me. I was surprised to experience the ESC failure causing this type of issue. Any help appreciated as to what this issue could be.
  21. Thanks rum4mo. The clicking noise comes on at startup and goes off. Then immediately I press the Air Con circulation button it starts clicking again, so I think it is related to the flaps.
  22. This noise appears to start when the ignition key is turned. I don't now think it is related to the air con/heater mechanism as the banging noise is heard even though the fan is not on. Could this be related to the fuel pump ?
