tibiking
Everything posted by tibiking
  1. When i look up the hardware nummber 7P6907357A I get the carsystems.eu Xenon Range / AFS LWR - Headlights Unit - Dynamic AFS1 Do you maybe have link the the sensor attsched in the wheel base rhe one you are refering 2?
  2. I got the following code i think its the master. What do you think? 55 Headlight Regulation System description: AFS-ECU Software number: 7P6907357A Software version: 0080 Hardware number: 7P6907357A Hardware version: H07 Serial number: -------------- ODX name: EV_HeadlRegulVWAFSMQB ODX version: 001120 Long coding: 03CA02003F000000 Subsystems: System description: LeiMo links Software version: 0009 Hardware version: H06 Long coding: 3E0000 System description: LeiMo rechts Software version: 0009 Hardware version: H06 Long coding: 3E0000 Trouble codes: C103415 - Left front level control system sensor Open circuit/short circuit to B+
  3. Hei i am an total newbie. So be Nice to me. Is this the location of the left afs control unite?. Cant see clear in the pictuee but is this inside the car at under the navigasjon screan or is this some where is side the engine Bay?
  4. Yea m8 thx that was some Great exsplainied. I was looking for a guide like these. But i order a New unite for like 450 euro. Now iam looking at selling me old one.
  5. Yea it was the rubber on the inside of the caliper just before the entrance of the main piston that was not alligned , was corrected the piston went inn like a dream =) now looks like i got some air in the system need to flush it ...
  6. Yes. I do Rewind IT clockwise. And IT Just feels like its losing grip. IT wont retract :/
  7. So basicly i rebuild the caliper put New seals and all that. But i csnt seem to get the piston to screw inn. Ps doing IT clockwise. But still the piston Just seem not want to screw IT selg inn. Anyone got an ide what could be wrong herr. Iam i using wrong lube? Using wd40 and some silikon lube.
  8. Thank for all the replays realy appriciate IT while i am doing the caliper rebuild was thinking on doing the break flush but wondering if any one know if there is an bleed ordre on the octavia mk3? I know that one some Fords you start one the right rear and thn left front its like an diagonal pattern. Any one know if thats the case whit octavias or how do you guys bleed flush your break system?
  9. there i brought the tools il keep you guys update on the progress , i want for the rebuild the caliper option , never done it before so yea wish me luck =)
  10. Soo basicly i need to replace the whole caliper??
  11. my qustion is do i need to remove the whole rear caliper , to install a new seal ? = )
  12. its an 1.6 tdi dsg whit manuel handbreak , do you maybe have a link or any sugestions on how to do this ?
  13. Anyone know what to do about this. Felt burning rubber smell while driving pull over saw smoke out og my wheel. Dis entall everything and this is the cause. Should i Just complete remove the rubber. Or do i need a New caliper anytimr SOON? Or any guide lines on how to fix this would be Nice
  14. True. I had big time problem if you read over my other post. By the way 1st time doing IT
  15. Saw the New breakpads are for golf vii and have an sensor on IT. My old ones did not have an sensor. Talked to the dealer and they Said that those breaks pads fit my octavia mk 3 acording to the car nummer and the vag pr nummber :/ Just wondering what you guys think. :/
  16. In the end i drille the top of the screw and the drill broken so i had the thing stuck inside whit rhe sides of the screw. Used an impact wrench the one you hammer on and IT turns while its digging in. Need to make New bearings in the hole noe. Will post pics when done.
  17. Gusess No one have one like these xD xD
  18. Dont have a chisel :( only thibg i got are some exstractors.
  19. Anyone have a clue how to go about to take the break disc off when the screws is broken?? :(
  20. yea the pr nummber is also is abscent on my PR list 2 , how do you know by looking up the VIN nummber what front brake disc and pads you need ? would appriciate if someone could help me out on this one =) realy feel kinda stuck :(
  21. most of the link are broken , do you maybe have some new ones , ? = )
