Everything posted by prt57
Boot light problems with Fabia Mk 1 Estate
I have bitten the bullet and ordered a complete new unit for peace of mind. Shame really as the mechanical components were fine. As this appears to be a fairly common problem you would have hoped Skoda would have just sold the part that breaks, especially in these times when waste is to be avoided. However, the metal lever that actuates the nylon cam had worn a groove so in time there may be other issues if the full movement was compromised.
I thought I’d update you with what I have found out. The photo shows that there are two micro switches in the electrical connection on the back of the tailgate latch. This part has just been unscrewed from the back of the latch. From my research about when the boot light will not work, there is confusion as people think there cannot be a fault with the latch switch when the boot light does not work if the warning on the dash still illuminates. I have worked out that when the micro switch in the photo near the green wire is depressed by the white nylon cam the dash light illuminates and the other micro switch operates the boot interior light. So one works by being pressed in and the other one relies on the internal spring pressure creating the contacts as the cam moves away. This is the switch for the interior light and so if there is poor internal spring pressure for some reason then poor contact results and the interior light will not illuminate. I had hoped to just buy a new electrical unit as the mechanical part of the latch is perfect. However, you have to buy a complete latch and electrics which is a shame. A replacement 2nd hand part from EBay may suffer from the same problems long term. Hope this helps someone in the future
Condensation and mould!
Water sitting on the seals at the bottom of the door is a sign that the metal internal door cards need sealing, possibly once more if not done properly last time. It would be worth getting the interior decorative door cards off for a poke around at the bottom of the door card seal. on my car, the rear door seals had gone mushy and were soaking. My car has the annoying rivets holding the metal door cards to the door frames so I could not get them off, however 15 mins of poking around pulled out the mushy seal. I let it dry out then resealed with a product from Screwfix called the Dogs Bo*****s. It is quite expensive but is sealed it perfectly and so no more standing water on the rear seals which then overflow onto the carpets. I have noticed that if I park the car at an angle leaning over slightly, I get water sitting on the front door seal of the higher side, so in due course, I will tackle the front doors. My son uses a moisture absorption product as shown below. I am going to get one as well to prevent our TT misting up in the winter. It will hold 800ml of water before needing to be dried out and then reused. Careful using a mould killer with bleach in as it may discolour the carpets etc. Those roof slots probably just had clip on covers and so would not be watertight. I may be wrong but I would not think water is getting in here. My car is an estate with roof rails so nothing to compare. Normally these plastic strips just cover up the channel where the side of the car is welded to the roof. https://www.halfords.com/motoring/car-accessories/interior-car-accessories/air-dry-classic---car-dehumidifier-170096.html
Hi, I think I have the classic problem with the microswitch in the orange part of the boot lock in my Fabia Mk 1 Estate in that the lamp will illuminate intermittently when the boot is opened. I know that the green and brown wire from the bulb holder is a switched earth in the lock mechanism and so has anyone devised a fix for this apart from wiring in a manual switch? Does anyone know the part number for the orange latch in the tailgate. With the internal cover in place the number is just hidden? Also what is the new cost of the orange latch as 2nd hand units will potentially have the same problem? I would like to get this sorted as at the moment, this is the last thing to fix on this project car! Thank you for your help.
