Davidoff1234
Everything posted by Davidoff1234
  1. Any guidance for this please I've had a search but it mainly brings up Octavias. Thanks 👍
  2. Morning all I Removed the door card panel to fix the door wiring loom and can't for the life of me see where the little plastic LED light goes to the door handle. I can see every other connection but a can't see how to refit it, does anyone have a photograph they could show me please. Thanks in advance
  3. Hi, I've taken the door card off and the music is playing perfectly, so perhaps it's related to the small speaker by the internal door handle ? Central locking still malfunctioning though (
  4. Do you know where to get the upgraded harness from mate ?
  5. Thanks I'll have a look at it later.
  6. Evening brothers. Mk11 2010 170 cr I fitted a aftermarket head unit last year and it's been ok. Few niggles as per usual with these aftermarket units but generally good. However the sound has started playing silly buggers Some days it's good no issues, then other days the sound will either go off completely or intermittently or play through just one speaker and then right itself, sometimes. Oddly it will right itself when going around corners or out of junctions etc. Has anybody else had similar issues ? Not saying it's the head unit but not convinced it's the vehicle either. Central locking also pleases itself which doors it will lock or unlock fortunately it doesn't affect the drivers door. Any info Will be appreciated very much.
  7. Evening all I wondered if anyone can help please. I've fitted an aftermarket Plus center head unit and all is good except the poor radio signal. So I've purchased a signal booster in the hope of fixing this. My problem is which wire is switched live (accessory) Red is 12v accessory as far as I can tell but it looks like it goes through the can bus. I don't want to connect this up and damage anything. Can someone please confirm where the signal booster power wire should go ? TIA
  8. Great explanation 👌
  9. So I've borrowed this and it's not picking up any stored codes even though dash has the lights on ?
  10. Ok I'll get it booked in cheers
  11. Old wheels back on and still getting this pesky abs eps tpm error ! Isn't allowing me to set the tyre pressure. Have done the steering wheel reset and no difference. Also getting a slowing down motion as if running out of fuel or braking. This disappears after pulling over and journey then normal.
  12. Yes mate. What are you thinking?
  13. So the wheels are causing the issue one way or another 🤔
  14. Judging by the old tyres vs new, the newer tyre valves appear to be slightly more rigid than the older valve.
  15. So the tyres need replacing with 225's ?
