Davidoff1234
Everything posted by Davidoff1234
  1. Brilliant thanks for the info 👍 😀
  2. 2010 superb Colombus head unit upgrade to Android ? Anybody done this ? Any recommendations please TIA
  3. Great thanks never gave YouTube a thought mate
  4. The front wing has bubbles forming along the edge alongside a plastic cover so I'm looking to rub down and paint at some. Is the wheel arch liner difficult to remove lads ??
  5. Take the blower out and get some grease onto the spindle wd40 will dry out.
  6. Evening lads Every now and then the superb turns over starts then immediately dies on me. Can take up to 4 attempts before it does start and run. Is this an ignition button issue or possibly something else in play ? Is there a thread on this subject ? I've searched a few different terms but nothing came up. All help appreciated. Tia
  7. So it's probably better to find some closer to the original offset ?
  8. Hi yes I thought that was the case. Any idea if they're the same fitment ? 18 18 inch
  9. Currently have what I believe to be Themisto alloys on. Looking to replace with the following Audi style 5 x112 ET29 225/40 Would they fit please folks. ?
  10. Hi does anybody know the alloy wheel size 2011 elegance please ?
  11. I'm going to see if mine does the same
  12. Mine powers up randomly sometimes radio sometimes bt. Its almost exclusively used in bt mode. I've switched off aux in and took the cd out to see if there's any difference.
  13. That's a bit rubbish 🤣 I knew I should have bought an android head unit instead of upgrading the bt module 😞
  14. Evening all Does the coloumbus have any settings available that allow you to chose what mode it's in on startup ? I.E can it be set to Bluetooth as default rather than radio? TIA
  15. Hi If you had about £500 to spend making this boring old elegance look sportier what would you purchase ? Cheers
  16. I've ordered a new upgraded one from eBay so hopefully it'll work now. Cheers
  17. Hi thanks for the reply. Will the updated version you mention allow Bluetooth streaming and will it stop the car taking over the phone ? Thanks in advance
  18. Hi pat Is this a simple swap or is there more too it mate ?
  19. Hi all I wondered if anybody has swapped the coloumbus for a android head unit. ? If so what did you fit and was there anything different you would do with hindsight ? Did you lose any functionality ie steering controls ? I've read that updating the bt module only allows for 3g data use which given I would like to stream music probably isn't ideal. Thoughts please. TIA
  20. https://www.ebay.co.uk/itm/175323415068?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=FenImsS1T6O&sssrc=2349624&ssuid=ZJhPyEx_RA2&var=&widget_ver=artemis&media=COPY Is this the one ?
  21. Replacement bt module ? Thanks for the reply mate.
