krisp1
Everything posted by krisp1
  1. At the left hand end of the glove box, the plastic frame hangs down unsupported. Remove the end cover plate and you will see a gap of about 10mm. I used a strip of plywood covered in insulating tape to fill the gap and stop the frame moving. It stopped the noise in my case.
  2. The flap release motor is supplied from a common source with the central locking(Red/Yellow). The other connection (Blue/Red) goes to the switch on the dash. The switch then completes the circuit to earth (brown wire on pin 2) when pressed. If there is not power at the motor there may be a poor joint where all the power is fed to the central locking.
