Everything posted by flynndog
VCDS Scan - What's The Diagnosis
I've a man said its the ccm or another module i can't remember reckons if its that it's a 120 bill. had 3 people out one came out for a full check of the car and never plugged it in so a polite phone call got him back the next day to plug it in and not have a clue what he was looking at 🙈 . I like the car a lot just a shame the hassle it's giving at the min whilst I'm off work waiting for surgery 😭
I've run out of "spare money" at the min so it's on hold for a week or 2 I've got it running with a wire giving live which turns the clocks on for me to start it not ideal but all I can do for now. The boot wont open from fob or boot switch. Rear 2 doors wont lock/unlock and screenwash has decided to stop working 🙈
Scout 2.0tdi non start and no lights on cluster
Right had the clocks checked they're OK. Autoelectrician came out this morning tested every fuse and relay all OK he bridged 2 fuses with a length of wire and got power to clocks and started the car it wouldn't turn off with key had to pull fuse. He said uts ignition switch so I've been and got one and fitted it but still the same 🤯 getting fed up of it now. Any ideas before I chop it up
Not that I know of
Where are the modules
Any ideas folks ?
I've put a new fusebox on off a car we know is all good and still the same. Feel like torching the fecker 😅 going to be without a car after weds so I need to get it sorted. The first lad who came with snap on reader is still convinced it's the cluster 🤷♂️ but the vcds didn't pull it as a fault
Stripped fuse box out water had got in cleaned it but too rusted so put another on from another car we know was good and still the same any ideas
Tried cl3aning it it was goosed. Tried another fusebox on off another car and no good still the same 😭
I've opened up fuse box under bonnet it's green and milky allover going to clean it best i can and try again
Locks and unlocks off key immobiliser light on and off as it should. Battery connections are good only have 1 key tried the tap trick and even stripped clocks out to check plug all seems OK 🤷♂️.
Without sounding too thick shall I unplug the fuses ?
What do i need to unplug ?
Will keep a close eye on any ideas what it could be.
Cheers for the scan @tetley appreciate it. Any recommendations very welcome i need to get the car mobile ASAP
It's as though weather has affected it to be fair but need to get it sorted the Mrs is going mad with me putting the dogs in the "family car" with the scout been poorly 😅
Just had another look to see if any miracle has happened and the headlight and indicator sign icons work 🤷♂️
Oh thank you. Ive sent a pm with my number bud 👍👌
Brighouse/cleckheaton area looks well that pod
I'll drop him a pm see if he gets it. As for my clocks there's nothing at all coming on no lights whatsoever no needle sweep just the little car showing doors open then it turns straight back off
It was a snap on reader he used this afternoon reckons he'll be able to do it with that 🤔🤷♂️. If he can't would your man be able to do it if I sent both the new (used) cluster with my old faulty one ?
I've thought of it but at that price it's cheaper to buy a set from a breaker and get a pal to code them in. I'm just wondering if the letter on the end of the code no I've got will make much difference 🤔
Lads been out and reckons it's the clocks ? Next question is which is the part no I need to find the same is it the 1z0920943d no ?
I've a lad coming to plug it in to see if we can find anything failing that we're going to get multimeter on it and chase wires. My 3rd skoda and the only one giving me problems 🙈
