Mxrco
Finding my way
Everything posted by Mxrco
  1. So apparently this wrc spoiler i can use for the roads so how can i put this. "apparently there is a tuv certificate so i can register it to my car if it makes sense.) Then again. I came across some videos and i saw some spoilers being flush or just glued on? Now my question is. Are these 2 spoilers diffrent from each other? If so. Would it be better for me to go with TIPE A one or TIPE B one? Unless i suck at doing research and they are the same thing. Thanks in advance.
  2. So im presented with a choice. Both are 18' and im wondering. Should i go with TE37 style rims (rotagrid drift) or XXR 527 ? Some pictures for reference. This one i saw scrolling on the forum so props to the owner. And the other i found online for the XXR's Also bonus question. Does the sidelight come with the bumper? Vrs version? Or is it custom made since im looking for it too.
  3. Kinda set on 18's but if i wont have any other choice + budget wise then yeah prob il need to go 17
  4. Yes mostly looks. I would of have gone with the 35 profile but i cant. The ones i can choose from are these. 225/40 R18 215/40 R18 205/40 R18 So either 205 or 215 would be my go.
  5. Thanks to both of you yeah. I looked online aswell and found both of the sites. Regarding legal reasons here in Slovenia i can apparently fit 205/40 R18 . And as i checked on the willtheyfit.com they should be okay. I think. Regarding the offset for the 18 inch rims and the rim itself (width) how much should i be looking for? Same offset as 15? so 38? And for the wheel width (the 18) Should i go for 6, 7? Or something else? Thanks!
  6. Unless these specs are the same which i would guess they are? These are the estate stats for 2003 but i have a 1u2 PD130
  7. Ok so. Right now im running 195/65/15 . About the et and stuff i dont know. Unless there is a way i can check this.
  8. Yeah i can go downstairs and check rq unless i got a picture. Gimme like a few minutes. And im not too sure man hahaha. Still young so i dont know all that. And the 18's are custom made. So i can either choose what i want but if i cant i can find the premade ones as u said above so 5x100 etc...
  9. So right now i have the "original" or "normal" rims whatever you want to call them but i want to buy some 18's from alibaba and they asked me for the following Diameter: R18 Width: Offset: Hole/PCD: CB: For car: Octavia Mk1 2003 I tried asking some companies that make 18's for the octavia mk1 for these informations but i got no reply back.... For the width if you could help me out what do you run on your mk1's and if you need spacers etc. And is it better to go for x/30/18 or x/35/18? Thanks! Also if it helps il either be running a rotagrid drift type rim or some bbs type not too sure yet. Thanks!
  10. So i dont want to paint my sun visors black so are there any visors from a car (black visors) that fit the mk1? Thanks. Or should i just paint them
  11. So i saw a guy on here post about the rotagrid drift tires and i need help with some dimensions if anyone can fill this form out so i can send them to the manufacturer. I woud need this Diameter: R18 Width: Offset: Hole/PCD: CB: For car: Octavia Mk1 2003
  12. Thanks il give it a shot. Right now im painting the a b c pillars black and putting a suede roof with 500 stars. Then il be switching the green interior lights to red/white so hopefully it will turn out great
  13. So im looking to remove all the buttons,switches,screens where there is the green light. Interior lightning basically. I posted before if anyone knows which type of smd leds i could use if even i could use but nobody knew. But hopefully some of you know how to strip down the interior so i can check it out.
  14. Hi. I need help if theese seats would fit no problem inside my mk1? Thanks. https://www.njuskalo.hr/kamperi-dijelovi/vw-passat-golf-4-seat-toledo-seat-leon-recaro-sjedala-oglas-46839510
  15. Also what kind of leds go into the door panels (window button etc/attached picture)? Since i figured the dashboard is 3528 smds Basically this all over the car + the climate buttons etc. The quality is bad since i just found it off google.
  16. So im trying to switch up the normal green ones to white ones and the needles red. And il be using this gauge So im wondering what kind of diodes the cluster uses because i havent opened it up yet and i want to order the parts. Thanks.
  17. Probably expensive though no? I've looked around and most of the seats i like are 1k+ . Cant find anything in the 500-800 range.
  18. So my original seats are pretty worn. Atleast the front driver one. And they dont offer any side support which i kind of want. So id like ether some cloth, suede, half leather ones. Preferably a set so front and rear but if not maybe a rear set that matched the front. Thanks. Sport-ish seats.
  19. Just ordered white H4 bulbs. Didnt go for osram night breakers since they were a little expensive. So i just went for some white ish ones from aliexpress too and bought the fog lights aswell with the position lights too. For like 12 eur. So hopefully it will turn out okay.
  20. Il probably pass for now haha. Will keep in mind. Might be my last mod if anything to be honest. Thanks tho.
  21. No not really. The only lights i like are the xenon ones. (Ones above) The ones you linked i saw but i feel it just wouldnt look right. Maybe a bit ricey. Didnt see them on an octavia yet so idk how to feel about them. I figured after this post i will just instal white halogens for low beam and maybe for high too. For the blinkers il use an US module.
  22. Yes I am aware of this. The law applies here in Slovenia too. I was just wondering what the process of installing it was. If its difficult and expensive etc. Thanks though!
  23. So right now i have normal halogen headlights which are nothing special. But i really like the vRs ones (il include pictures below if i find them) What would i need to do to make them function like a normal feature? I know you need a levelling sistem so the xenon lights face downwards if the car is facing upwards or something like that? What would the steps by steps be? What would i need to buy and install? Is there a video of some sort? And is it worth it? Thanks.
  24. So i have a mk1 96kw tdi and im thinking of working on it a bit and my question what kind of restrictions does it have? (2003 model) Muffler and cat i know i think but are there any more? Thanks.
  25. This is my one. I dont see a reason why it wouldnt fit? Sorry if its too many questions just pretty young still learning haha.
