Interior disassembly help
So im looking to remove all the buttons,switches,screens where there is the green light. Interior lightning basically. I posted before if anyone knows which type of smd leds i could use if even i could use but nobody knew. But hopefully some of you know how to strip down the interior so i can check it out.
Well, you need to be a bit more exact about what you want to take apart. theres a lot of different bits. numerous guides for different jobs will have instructions for taking that area apart.
eg threads on door lock issues will tell you how to disassemble the door cards - including the switch modules in them.
if your even reasonably handy with a screwdriver and torx set (im assuming you must be if your willing to tackle led replacements on circuit boards) you figure it out pretty quick.
top of my head - the headlight switch >
put it to the corner lights (12 o clock) push the switch into the dash, rotate it and then it will pull out.
Thanks il give it a shot. Right now im painting the a b c pillars black and putting a suede roof with 500 stars. Then il be switching the green interior lights to red/white so hopefully it will turn out great
