Oil for 1.5 TSI
1:Yes 2:Yes 3: 4.3 litres (Service fill)
Problem with fault in heating and air conditioning system
U1030 Meaning Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an identification number with at least one critical parameter within 5 seconds of beginning serial data communication, the Diagnostic Trouble Code (DTC) is set. So you have a canbus datalink problem, or it might be a sensor that is built into the radiator. Not a spare part so new radiator required.
which vrs battery - confused
The battery management system, needs to know the battery has been changed to adjust the charging curve for the new battery. The BMS is tied into the alternator freewheel clutch, and the start stop system.
VRS front shock heavy mist/leaking ? give me your 2 cents
Surprised that past the MOT, looks like pretty severe leakage to me. I would change them.
Do I need to change both tyres?
Good to see someone putting safety before cost. You will be fine with a 7mm tread on one tyre and 8mm on the new tyre. Provided the new tyre is identical including the load rating. I know of people who had traction control problems after fitting a new tyre, when the other tyre on the same axle had 5mm tread remaining. This was with the Kona EV running Nexen tyres.
4th Gear does not engage
- Bonnet bras - Yea or Nay?
I'd rather deal with the stone chips than look like a tit. 🤣- Octavia VRS, failed repairs under warranty and now likely head gasket (out of warranty)
Thanks for the update. Plus a happy ending. 😀- DSG not changing up
There's a new fix for the 'Park' warning. Used to be a new gear selector assemble,, now it's a new micro switch. As for not changing up, it could indeed be the EGR as EGR values are directly related to engine load, and it's a closed loop system,, so gear change mapping can be messed up if EGR values are wrong.- Octavia VRS, failed repairs under warranty and now likely head gasket (out of warranty)
Might be the same fault symptom (coolant loss) but if it is the head gasket, different cause,, so not covered by recently replaced parts warranty. The car is now 6 years old, so I doubt Skoda UK would even consider a good will gesture at this point. There are only three head gasket thicknesses available, so if any skimming is required any warping will have to be minimal. so minimal cost will be light machining of the head, new gasket, and a set of new stretch bolts (old bolts must NOT be reused.) Plus of course labour costs. These heads sometimes develop cracks between the valve inserts, so that would be a new cylinder head.- Get it Ready For Winter
Title say sit all really... Battery, should be 12.5 volts minimum after 2 hrs of non use. If it's less than that, consider a new battery. Diesel batteries get clobbered, and with PAS alone capable of taking 60 AMPS a good battery is essential. Screen Wash. Use plenty of screenwash additive to prevent freezing of washer fluid. Too little and you risk blowing pipes off the washer pump or tailgate fittings. Wipers. Check blades are in good condition. Don't operate wipers if frozen to the screen. If you do F15 will most likely blow. Tyres. 3mm minimum tread. 1.6mm is the legal limit, but you really need 3mm or more for winter use. Check the spare wheel condition and pressure, Nothing worse than getting a puncture, only to discover the spare is flat. Aircon. Use it now and again during winter to prevent system seals drying out and leaking due to lack of use. Carry a bag of rags to clean lights between washes. Edit: Have anti freeze protection level checked. 50/50 G12 works nicely- Excellent Free Service Manuals
Found a source for Skoda Technical Manuals. Much better details that the Haynes manual, and on page two of the downloads, the 0A8 gearbox manual is available. Free File Hosting Made Simple - MediaFire - Bonnet bras - Yea or Nay?
