matt_j
Everything posted by matt_j
  1. Any info or how to's in this would be great, need to change the elements on the driver's seat, cheers
  2. Fault found! Scanned with my friends code reader and the seat seems to have tripped out, deleted the code and it's working again, the fault was heat temperature sensor short circuit so if it happens again it'll be the base pad need changed as this has the thermostat in it
  3. Don't know why I'm bothering to update as help seems few and far between on this subject, checked what I assume to be the correct wires from the base heater and back heater and I'm getting 2.0 ohms and 3.2 so my guts telling me it's the thermostat in the base heater that's toast, will report back if I get to the bottom of it, so you don't have the same grief as me πŸ‘
  4. Does anyone know how to check the elements? The wire colours and the expected resistances? Had a quick look this morning, seat out job for me and get to anything and the wiring is all really tight and inaccessible
  5. Checked that budd, it's fine πŸ‘
  6. Checked today no code errors 🀦
  7. Wirings good, horrible feeling it's a burnt out element ? As in code reader for fault codes?
  8. Evening all, sorry if this has been done to death but my drivers seat heater has stopped working, the cars light up on the switch briefly then go out, passenger seat works ok so I'm guessing that rules out the fuse
  9. Hi, pads virtually new, brake fluid changed 2 years ago for motul stuff, 47,000 miles on the car, can't feel any lips on the discs they look perfect
  10. Afternoon all, So did a fair bit of motorway driving yesterday and noticed and intermittent noise while braking, doesn't happen everytime I brake which makes it harder to understand, more than likely from the front, any ideas, common issues? Discs look fine and pads, could be a warped disc but thinking the noise would be constant πŸ€”, as ever any helped appreciated
  11. Flashing, fail lights it is them 🀣🀣
  12. Evening all, Apologies in advance if this has been discussed before I did search and couldn't find what I was looking for. So I want to fit a towbar and I'm curious about the electrics/wiring, you can buy a trailer control module for this but I don't want to pay Β£150 for the privilege, I had the idea of making an inline twin plug loom so it will be plug and play, but is there a reason this isn't done factory? Will it cause canbus errors πŸ€”, any info greatly received
  13. I had an S3 brand new that never had it either assuming these are the MQB platform πŸ€”
  14. Never had the issue until now 🀷
  15. So went in today two test drives and an MOT tester check on a vibrating knock test machine thing and no faults found 🀦🀦
  16. Thanks both, it's going in the garage Friday for diag I'll do the work myself just couldn't find anything when I looked
  17. Morning all, Im looking some help advice, i have a mk3 estate VRS DSG diesel PFL and it has a clunk,knock,creak from the front end, I've had it up in the air this morning on a jack, wheels off had a dig around cant see anything obvious, no snapped spring, balljoints all appear ok, the droplinks dont seem as tight as id expect but this is the same both sides, is there any common issues associated with these front ends? I had a mk6 golf and they were prone to chassis creak, there was a mod kit released that was basically a serrated washer that went between the subframe and the car body, any help gratefully received.
  18. No idea 🀣🀣
  19. Thank you sir ☺️
  20. Evening all, Octavia VRS 5e 2015 Sorry if this has been done to death my apologies, id like to fit a sat nav to my car an OEM direct replacement would be ideal, does anyone have the parts numbers for a compatible item? Please and thank you HAPPY NEW YEAR!!
  21. I have a battery tester, ill chuck that on it when i get home and say what it says πŸ‘πŸ»
  22. 36k battery has been tested 2015, yes i understand ppl may comment but i may be being overly critical, i mean it starts 🀷
  23. Morning team, Just back into a skoda and its ever so slightly hesitant to start, is this common? 2.0 TDI engine, its very minor but noticeable just to statisfy my curiosity, cheers
