varooom
Everything posted by varooom
  1. I don't think the VAG would release an update that could break their own radios, could be wrong. I can send the file and you can do more research to see if you need to muck about with parameter files.
  2. Press and hold down the Menu or Setup button for 10 seconds to enter the Engineering menu, locate page where Software Train is found (hopefully!)
  3. You are welcome, Optionally you can update the maps to newer version, even if you use phone, this makes for a good backup.
  4. It doesn't matter that it's in Swedish (other than me not being able to read it) The firmware is EU, so has languages for Europe. Only a small bump to 0480 is available, will send via PM.
  5. Maps SD Card 1 (for those that need permanent card inserted) Music for me in SD Card 2
  6. 0480 is the latest version, sent via Private Message system.
  7. If you want firmware, press and hold the menu/Setup button for about 10 seconds. Look for Software Train
  8. Nothing if your software train is matching.
  9. I can send you firmware update to 0490.
  10. You can update firmware to MST2_EU_VW_PQ_P0254T version, but this will maybe need activation by dealer or if you a lucky another method. I can send this by PM, and you can choose to apply.
  11. I can send you 0480, but this might be a physical fault
  12. You already have the update and applied it, not sure why you need to have same file again, it won't load if you are on 8755 version now.
  13. I have already... top right of screen you have a private message waiting for you to read 🤝
  14. Ok, I can now send you 8755 version
  15. You need to find a Software Train from your car. Hold down the Menu/Setup button for about 10 seconds to enter the engineering menu, then post back details or a picture.
  16. To rule out human factor (me) Check your metainfo2.txt Should contain these lines near the top [common] Release = "MST2_EU_SK_ZR_P0480T" MUVersion = "0480" Vendor = "TechniSat"
  17. You need to be on this page here to push that update button. The file I sent needs unpacking to the root of a FAT32 or exFAT formatted SD Card, not to a folder like E:\MST2_EU_SK_ZR_P0480T The root of the SD Card should contain a single file called metainfo2.txt, and then a collection of 38 folders
  18. Try to check out specs on these units, look at some YT vids. They are in dollars, so not sure if they can be purchased. https://connectpro.com/ Do you have more detail for your post refresh rate of screen inputs on the monitor two pc's and one monitor?
  19. Yes, and benefit it a bigger number, 0421 --> 0490 Normally they fix bugs you may or may not be aware of, like system speed and Bluetooth stability etc
  20. Yes that's original fitment.
  21. Sounds good, best of luck.
  22. You need to wait about 2hrs for the car to settle before getting readings, or overnight. I changed mine early, as it was sitting around 12.1V after being left for days in the cold of Winter, it never struggled to start, but you could tell it getting towards end of life. You might be able to get battery cheaper, but if you don't have VCDS or similar, adapting battery could be an issue. £160 is not too bad (but depends on what is fitted now!)
  23. Yes, 0480 as above for you
  24. Yes, it is only a small jump to 0480, but can be applied of course. PM you in next few moments.
