RIncewindwiz
Everything posted by RIncewindwiz
  1. OK for anyone who might be interested: 1. To free the bonnet get one person to pull on the opening handle while another jumps on the front of the bonnet. (Bang with palm of hand; short hard push down). If there is only 1 of you, holding the handle pulled tight with a piece of rope through the door pillar worked for me. 2. Before working on the catch at the bottom, check that the clip on the top of the bonnet moves freely from side to side. If you dont get a click when you pull the opening lever it is likely that the top clip is jammed. Clean it up with a stiff brush and liberal application of WD40 3. And of course while you are there, clean and WD40 the bottom catch.
  2. Unusual. The bonnet is slightly open - not far enough to get fingers underneath to the release catch but certainly enough to get a screwdriver under and lever the black plastic catch. But it wont budge and the bonnet wont open. - Pulling the release lever does nothing - Pushing down on the bonnet does not move the bonnet at all - Pushing down on the bonnet while pulling the leaver does nothing - Pulling up on the bonnet does nothing - Levering up the black plastic release catch under the badge does nothing and it was only 2 months ago when I gave it a good working over with WD40 Any suggestions as to what is stuck and how I might free it?
  3. Weird indeed. Started the car this morning and all windows work fine. Good news . but worrying though in case it happens again
  4. My electric windows went doo-lally today. Sadly I wont get the sequence exactly right because it was all a bit random but essentially . . First a back n/s window went down by itself so I put it up again Then O/S windows (front and back) would go down but not come back up. (n/s OK) However, holding down the lock button makde all the windows shut correctly (but after it shut the drivers window had a couple of hiccups like it wasn't sure it was fully shut) Now all windows are shut and only the rear N/S opens. 4 hours later I tried again and now all windows (except the drivers window) operate correctly! I thought I'd disconnect the battery tomorrow to see if that resets things. Any other suggestions?
  5. I did ask yuasa in my discussion with them about the state of my battery. They said "With regards to charging, our normal suggestion would be 1/10th of the label rating for general recharging. If the voltage is sufficient, you will charge a battery even if the current is lower, it would just take longer to do so. To much current is not recommended as this can cause thermal issues inside the battery if used too frequently. " So it seems that 7A not that critical and 8A, if not used too often, will be fine
  6. So I see you guys have been having fun with my thread 🙂 - good interesting stuff I decided my battery was effectively dead (in that it would not drive start/stop and gave up the ghost after parking for short period swith the lights on) biught a new one , adapted it and start/stop works fine again. Thanks to all that contributed.
  7. Charger on car for < 2 hours (I looked after 2 hours and it was fully charged) Plugged into 12v - Only a GPS watch FYI I sent Yuasa the charging readings and they replied 12.58v would not be a reading we would see for a fully charged battery. If it is dropping to 12.18v after a short period of time, that would suggest that the “surface charge” is dissipating leaving a voltage figure of less than 50% state of charge. This could suggest that the battery is deeply discharged and very likely sulphated.( Which would explain why the battery is not reaching a full charge- the ability to store charge is reduced by the build-up of sulphur on the battery plates) The lifetime of any battery would be reduced if it subjected to frequent use at a low state of charge. Testing the CCA reading using an appropriate tester would confirm if the battery were indeed sulphated. On the basis of comments here (thanks to all that have contributed) and from Yuasa, I am inclined to give up and get a new battery.
  8. So the following readings (multimemter between battery terminals) Before charging 12.3 (back 30 mins previosuly from 10 mile drive) Charger finished 12.6 10 mins later 12.25 (time taken to put everything away) 2 hours later 12.18
  9. Interesting stuff and thank you (I've an engineering degree and so the sort of odd mind that finds this stuff interesting!) Cant do this until tomorrow as I am about and about for the rest of the day. Will do Thu morning and report back
  10. Multimeter readings at battery terminals All off (no lights no ignition no engine etc) 12.29 Headlights (dipped) on all else off 11.63 Engine running tickover all else off 14.6 - 14.7 fluctuating Readings taken at chassis earth differ by 0.01V from those at battery terminal Internal readings (taken earlier) at the cigarette lighter appear to be 0.2 volt lower
  11. My Mk3 Octavia Owners manual only has 264 pages 😞 Any chance you could add fig 336
  12. Incorrectly to the two battery terminals. Can anyone give me a clue as to where to find the chassis terminal? If it s only at the other end of the battery lead I dont see the point (as battery lead connected to battery) CANCEL THIS Found it Charger can be found here https://www.amazon.co.uk/Matthew00Felix-FOXSUR-Repair-Charger-Motorcycle/dp/B07W6HGMXW Start Stop didn't work yesterday after what should have been 30 mins on a motorway and turned out to be an hour on back roads!!! I happened to notice at one stage the battery charger said it was putting out 1.8A but its a 70Ah battery so up to 7A is OK? Will finish coffee and go measure voltages (no load, under load [lights] , engine runnning) with a multimeter across the battery terminals?. Anything else I could usefully to measure. I will get a measurement from cigarette lighter socket gadget as well
  13. HI and thanks for the interest I'll answer as many as I can; rest tomorrow Battery Charger Charging: Battery behaving as usual. Connected charger to battery in car (so 'on car') and left it. Came back 4 or so hours later and the charger had turned itself off 'cos battery was 'full' Charger is a FOXSUR model FBCX122308D 12v 8A / 24v 4A charger Charging figures from only 1 instrument (connected to cigarette lighter socket) Can do again with multimeter directly to battery terminals VCDS does not report voltages other than terminal 30 (wherever that might be) which was reported during the scan as different values 11.4 (near the start) and 12.0v (at the end) Off for a 30 minute M-way drive this evening (and 30 min back) so will check after that and test tomorrow
  14. No lights on. It used to work fine. Then I started having problems starting on cold mornings and if I left the lights on so I changed the battery Every since changing the battery Auto Stop/Start has not worked - except for a short while after long journeys
  15. Charged battery until charger turn off because fully charged Went on short (7m) run. No autostop/start (Just the capital A with the line through it)
  16. Thanks. I thought I had said . . . . . This battery has been like this since new (it is now 2 years old). I complained afer about 6 months but was told I could pay for some tests or go roll my hoop Serial number changed for the first time 9 months ago. Anyway, I think Ill just have to get a new battery
  17. OK Checked Capacity 70Ah Technology Fleeece Manufacturer JCB Serial No 1111111112 changed to 2023012211
  18. Thx As above, I will go check. and report all the settings - and I'll change the serial number again!
  19. Thanks I downloaded and followed your excellent battery adaption thread slavishly and will have used the values you recommended (70Mah, Fleece, serial number last digit changed by 1) - I will go check as when and if the temeprature gets above freezing! IIRC I posted that I received Adaptation Error for uninitialised control module and you advised me to take the default offered ( Start/Stop etc has always worked as described above. I put it down initially to incorrect adaptation but then discovered your thread, went through the process about 9 months ago and its made no difference.
  20. Hi All I bought a new battery (Yusa 9000 AGM YBX 9096 see pic) a couple of years ago, Although advertised by the supplier as OK for the SKoda it was not a make known the the Battery Management System. So I used VCDS to change the serial number in the hope that technology would treat it as a new battery and work out how to charge it properly. This seems not to have happened I've been running withoiut Auto Start Stop (except for a brief period after a long {>1hr} drive) since then {no great hardship!}). Occasionally I would get a low battery warning but it always went away after even a short drive. Then recently a few days of short urban trips followed by parking with the side lights on for 90 minutes produced "Low Battery Charge by Driving warning" and difficulty starting. Charging voltage is around 14.4 – 14.8; Not charging around 11.8 - 12.2 VCDS reports no battery related problems (as far as I can tell) So any suggestions as to why the battery does not seem to get fully charged and Auto stop/start does not work
  21. Will see how it goes Thanks for your process and advice
  22. Thx Happy to take defaults And I'll invent a serial number Is this likely to fix the problem
  23. Sorry - I screwed up I followed the picture (which has 01 Engine highlighted) and not the words (select 19 CAN Gateway) Yes I know, moronic is being kind!! My battery is YUAUS YBX 9096 AGM 70Ah and its been behaving badly- Autostop/start does nto work; tend to get low battery warnings but it all works fine if I use a batter charger so I presume something is wring in the settings hence the need to change Anyway second problem (after I worked that out) All goes fine until I try to mak the first change (capacity) Stored Value is 68 My battery says 70 So change that and a pop up says Application error and provides options. Which one - or doesn't it matter? The rest of the stored info appears to be trhe defaults you mention JCB Serial 111111111 Type Fleece Screen shopt of erropr msg and picture pf battery attached Thanks for any inf
