Where can i get speaker adapter collars for Mk2 octy
Anyone know where is can get speaker adapter collars for front and rear doors?
(Yes, i googled!)
Chris
Do they actually need any.What size speakers do you wabt to fit?
Replace the 17s at the front with smethng a bit better but not over the top. Probably some e-series pioneers that don't need extra amping. Replace the rears similarly. The rear are 14cm?
an you simply remove the existing speakers and use the existing pop rivet mounts?
Rgs
Chris
No one? boo! :rolleyes:
Chris
You should be able to remove the old ones and replace with the new as long as they are the same diameter
Really? I thought it was sealed in? i'm gonna do some investigation at the weekend anyway by removing the door card.
Cheers!
Chris
