Bulkhead wiring???????????
Ok guys, had a bit of spare time today and decided to wire my amp...
After about 2 hours, 3 cut knuckles and lots of swearing and pieces of car removed, I just cant find any way of routing the live wire from the battery into the inside of the car... (OctaviaMk1)
PLEASE HELP ME!!! :confused::confused::confused:
It's so frustrating when you know the whole thing should only take about 25 mins:mad:
If anyone's got a picture, that would be REALLY good..
thanks
:cool:
Its behind the glove box.Theres a rubber grommet.
WHERE ???
I took the glovebox out... I could see the airbag, and a mass of plastic boxes and wires..
I even stripped the carpets out and the padding underneath to have a look there..
PLUS i looked at the drivers side, I just couldnt find any where with any grommet/hole:mad:
Thanks!
:cool:
BUMP!
Anyone? I really wanna get this cracked today... !
(Or is there another live I can patch my wire into inside the car??)
If you open the bonnet and go to the right hand side against the bulkhead there is a fuse/relay box underneath this there is a wiring loom that goes into the car it is quite close to the inner steel wing where it radiusus for the suspension towers, push it through that it should appear on the left of the glove box.
