Fabia vRS chipped
can somebody give me some stats on the car when it has been chipped pls thinking of buying one but wanna know how much they can be tuned
Mines been done by Revo
Supposed to be 180bhp ish and 300lbs ish, but its going on a rolling road tomorrow..........
Most companies seem to produce similar figures
Mine is much happier to rev to 4k, smoother and pulls hard from 2k to 4k now
Highly recommended :cool:
0-60 goes from 8.5 ish to 7.0 ish
0-100 goes from 24 ish to sub 20
HTH
And after that you can add a free flowing exhaust with either a sports cat or decat (decat can loose a bit of torque though). Either a different or modifed turbo to run higher boost at safer levels (std turbo has been known to bend the compressor wheel if pushed to hard) and it will also spin up quicker. Then maybe a larger front mounted intercooler, wont net you massive gains but will reduce inlet temps which is safer for the engine.
Then you will need to upgrade the suspension and brakes, all of which have been discussed recently to have search about the site.
I have the above by the way, intercooler is being made up as we speak. ;)
Ross, out of interest, where will the intercooler fit? Seems very tight in there from what I can tell :confused:
And after that you can add a free flowing exhaust with either a sports cat or decat (decat can loose a bit of torque though). Either a different or modifed turbo to run higher boost at safer levels (std turbo has been known to bend the compressor wheel if pushed to hard) and it will also spin up quicker. Then maybe a larger front mounted intercooler' date=' wont net you massive gains but will reduce inlet temps which is safer for the engine.
I have the above by the way, intercooler is being made up as we speak. ;)[/quote']
... which is nice :thumbup:
The new Ibiza Cupra PD160 has a fmic.
There is loads of room behind the Fabia vRS front bumper as it was developed as a homologation part for the WRC car.
