Re-map/clutch advice !
Hi All, recently got myself a one-click and must say its brilliant, very recently though the clutch has started to slip a bit which is a bit annoying as the cars only done 22,000 :(
I was thinking of getting an Allard uprated clutch plate to go in my standard clutch ! anyone used one of these or any other brand ?
Would I have to buy a new pressure plate and bearing to go with it and is the clutch do-able at home ? I have a pit and plenty of tools...any body got a Haynes manual for sale....:D
it is possible to do at home by a competent diy er,search for skudmissiles thread on it with pictures too:thumbup:
I am one of two on here with the spec stage 3+ and spec 4kg billet ally flywheel,but its a bit of overkill if you only have 1 click,as this setup is rated to 600ft lbs:eek:
