Forge turbo inlet pipe
Hi all
just bought a forge turbo inlet pipe from ebay for
Nat,
Prepare to lose some skin from your knuckles!
Andy
Hi there... where did you go on ebay to find the pipe? Is the pipe only for a skoda or is it generic what am i looking for when looking for this item!!!
Does the pipe give it more hp ?
cheers
andrew
cheers
andrew
I'm guessing this is the same a the Samco one piece TIP that goes from the MAF to the turbo? If so Impossible Performance were dong these for
cheers
andrew
just type in forge/samco turbo inlet pipe,i was lucky there was only 1 available at the time.yes it's the same pipe for all 1.8t engines except agu(non dbw)there is a different pipe available for these engines.yes it does give more power and torque,it flows around 70% more air than standard(factory metal inlet very restrictive)the forge is made of sillicone and replaces the factory rubber and metal combination.
hope this helps
if you are interested there is one for sale on uk-mkivs in black
