Cruise control help
Hi guys, some times in my car the cruise control wont work, but if i turn off engine and turn back on it works ok... any one else have this problem?
My warranty runs out in 2 weeks, will it be covered? i also have a remap so will they check?
You need the fault codes read, could be a few things. No reason why it wont be covered by warranty.
They shouldn't be concerned about the remap, unless the fault is in the engine ecu which is possible but not likely.
Dont mention the remap and get your brake light switch checked out.
Only £7 from a dealer if you want to do it yourself and a really easy fit.
thanks for the help, will ring skoda tomorrow :thumbup:
