Removing washer fluid pipe from rear windscreen wiper
I am trying to replace my rear windscreen wiper (motor included). The only part I can't remove is the pipe that brings the washer fluid. Does it screw off or do you just pull it?
Thanks!
Most just pull off, my A3 one did.
You were right. I think there was a little bit of glue on it but a pair of pliers and a bit more force did the trick. Thanks!
