Audience + Skoda Sound system Problem
I've just benen trying to help a mate out & we've found a problem that can't be unique!
He presently has the Audiebce HU fitted to his Octy Sports. However he's had a few problems with it and taken it back to the dealer to be replaced under warrenty. The dealer has tried 2 different HU's and "not been able to code them in & get them working"
So we tried fitting an MFD 2 this evening. All works except there is no volume & VAG Com lists a string of faults as follows:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 2900105220090F
Coding: 3D3F034A071303
Shop #: WSC 73430 790 00000
3 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 21
Reset counter: 77
Mileage: 41757 km
Time Indication: 0
Date: 2000.00.00
Time: 17:36:29
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 77
Mileage: 42199 km
Time Indication: 0
Date: 2000.00.00
Time: 18:36:13
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 37
Mileage: 42199 km
Time Indication: 0
Date: 2000.00.00
Time: 18:57:42
Address 37: Navigation
Cannot be reached
Address 47: Sound System Labels: 1Z0-035-456.lbl
Part No SW: 1Z0 035 456 HW: 532 226 800
Component: SK35-DSP 4 1000
Revision: 4 Serial number: 00002585
Coding: 0000000001
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Time Indication: 0
I've tried all the code helpers and reset the unit, but there is still no sond, except when you enter the Sound system control, then there is sound very briefly. When you re install the audience, it seems to work fine & the faults are not there. Ive no idea what codes were generated when the dealer tried the other 2 audience head units, but suffice to say they didnt work either! I must be missing something!!
Any help welcomed, as I can't see why only one HU will work, but as I say I might be missing something obvious!!
Edited by uncle bulgaria
I'm fairly sure that a MFD2 will not work with the Soundsystem.
I am led to believe a MFD3 will work.
As for the Audience then surely the dealer can sort that?
Oh dear, I hope your wrong Hedge
If not there will be an MFD2 for sale shortly :(
However, no matter if it is compatible with the sound system or not, we still need to solve the problem.
I took my car in under warranty as the Audience stereo works fine but was showing a fault code.
So far its had 2 new Audience H/U's but they cant get them working.
Only my original H/U works :confused:
It must be the coding
We need to find out why my speakers will only operate with the original H/U, as its obviously not a physical problem
Any help much appreciated
TIA
Damian
:eek: I hope that's not the case either!!
As you say we need to find out why only the supplied HU will work :confused:
Seems curious as Stu's "how to" lists possible codes for the MFD2 with a sound system :confused:
As Damo says, we'd welcome any help!
The sound system has an amplifier that is turned on by a CAN signal. No ordinary lead with 12 volts.
The MFD² cannot send this signal.
That is why the Nexus never has been in the optionlist with the soundsystem.
The newer Columbus (RNS510) can provide the signal.
Here in Germany a former user of the octaviaboard had engineered a little device to turn on the soundsystem amplifier with other HU than the Audience.
They sell the box for about 100 euros + postage.
If you want me to look in the other board, I can tell you how much it actually costs and send the contactdata.
Thanks but I think I will probably sell the MFD2 and start to save up for an MFD3 :(
Yep, that is still the best way to go. Had a Nexus myself, replaced it with a MFD²DVD (already a far better navi than the Nexus, soundwise as well as europewide navigation on one disc) and after that I bought the RNS510.
Not cheap but a wonderfull piece of in car entertainment including navigation. And also fully compatible with the different soundsystems of the VAG cars.
Thanks for all the help Magic62 and liking your choice of BBS Alloys :D
I (we) love em :thumbup::D
  • 2 years later...
The MFD� cannot send this signal.
Hi
I am having a problem upgrading to a new head unit and need a way to switch on a DSP amp. You say you know someone who makes something that can do this? could you put me in touch with them?
thanks
Oliver
  • 2 years later...
Hi magic cud u plz tell me from where n how I can find this device to turn on my audience amplifier so I can upgrade my HUD I'm having a skoda Octavia II 2007 model
Hi I'm having skoda Octavia II 2007 model fitted with audience MP3 player n dsp sk35 1z0035456 I just want upgrade my HUD from audience to bolero but whenever I try to upgrade the player there's no sound in speakers cud any person tells me how can I upgrade the music system without changing the dsp
