Eibach springs. Are they sided?
Fitted them about 1500 miles ago, so they have had plenty of time to settle down, but the o/s/r sits higher than the n/s/r, and the n/s/f sits quite noticeably higher than the o/s/f
I checked the numbers painted on the springs before fitting, and im 99% sure they were the same numbers on both fronts, and both rears...
Hi
No they are not sided , sorry :(
But may be worth just checking that they are all the right way up and that they are seated correctly
Good luck my dear
Sarah
shocks nackered?
Hi
Good luck my dear
Sarah
Yup, they are both seated right, top and bottom. The writing on both of them are the right way up...
shocks nackered?
The o/s/f had a new shock approx. 15k ago, so i would expect that side to sit higher, but its the passenger side thats higher (on the front at least)
"shocks knackered" will have no bearing on the vehicle ride height
why don't you swop the 2 rear springs over , to see if that makes any difference
