EGR Valve Disabling?
I read on the FABIA forum about how you can use VAG-COM to re-code the action of the EGR valve to minimise the incoming exhaust gas (and the associated crud) from the intake manifold without having to use a blanking plate. It was a modification to Block 3 under Engine Adaptation....
Will the instructions work for an OCTAVIA Mk 1 Tdi 110?
